TSSA - The Simplest Symmetrical Amplifier
Old 20th April 2012, 07:42 PM   #171
Idefixes is offline Idefixes  France
Idefixes's Avatar
Send a message via ICQ to Idefixes
Layout related the schematic above. Output BJT are mounted under PCB but not sandwiched by screew between PCB and heatsink
website : http://audiyofield.wifeo.com/index.php
Old 20th April 2012, 08:15 PM   #172
Idefixes's Avatar
Originally Posted by Lazy Cat View Post
- TLP627 input now accepts 12 V remote signal (serial resistor added)
That' mean that i can drive TLP627 by my speaker protection board. this use 12V relay mounted on satellite pcb board? I just have to keep sensing wire comming from amp board output (speaker out)
Old 21st April 2012, 12:31 AM   #173
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Just came home from the party Marc PCB looks great, will do check-up tomorrow, regards Andrej.
Old 21st April 2012, 06:09 AM   #174
Idefixes's Avatar
Hi Andrej,
Some more minor cosmetical changes to improve visual symetrie :
-position of tlp627 power supply resistor (to use with 12v)
-position of 10k at signal in.
Old 21st April 2012, 10:48 AM   #175
Lazy Cat's Avatar
First of all I really have to express my compliments to you for all your work at TSSA BIGBT HP PCB, the board is amazing according to my standards. Look, for only one layer PCB, drawn from medium complex schematic, there's only five wire jumpers, that's is a remarkable achievement. Hats off to you Marc.
I checked schematic separately and here we go:
- Q7 BF245B, B marking is missing
- C11, C12, C13, C14, C15, C16 are now 100 V marking, if someone will connect optional front-end power supply, that is normally +/- 5-10 V higher than the output power rails. According to given voltages table, front-end rails would be in a response +/- 35-85V. So 100 V capacitor potential marking is on a safe side in all circumstances
- erase GND symbol near C6
- connector J4-1, J4-2 is unnecessary, if there is no need to have remote on/off, than TLP is simply omitted and its pins 3 and 4 are connected with wire jumper
PCB check-up:
- R33, R34 rotate 90 and reposition as now, unisolated part pin too close to PCB edge (elcos can be at the edge - isolated body)
- omit connector J4
- position TLP, R35, LED7 as on pic
- C13, C16 are 100 V, now same diameter as C40, C44
- C12, C15 repositioned
- R23, R24 fliped horizontally
- MUR460 moved away from MJL-s, reposition them as now
- J9, J8 GND connectors moved to middle GND, as now better prevents GND interference currents
We are a tiny dot away from final PCB. Today I will check connections-tracks according to the sch.
Best regards, Andrej
File Type: jpg TSSA_BIGBT_HP_50vdc_V62_brd_compo MOD.JPG (208.8 KB, 253 views)
Old 21st April 2012, 01:12 PM   #176
Telstar is offline Telstar  Italy
Originally Posted by Joachim Gerhard View Post
I build the super simple version of post one. It worked right away.
The sound is a bit lighter then with my power buffer ( see MPP ). By adjusting the gain in the preamp and using a warmer sounding cable i got it going. I have to listen more but the amp is very transparent.
Hi Joachim,
I'm considering this as headphone amp. Can you link the final circuit of your MPP (i found the thread but it's huge)?
"The response of the inner ear extends to at least 200khz" Dr W. Tempest
Old 21st April 2012, 01:16 PM   #177
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I build it like post 1 on this tread. What i added is a cap multiplyer in the PSU plus an input RC filter with 220 Ohm in series and 150pF to ground.
I will publish that circuit here soon. For a headphone amp this is a bit overdimensioned so be carefull with the volume.
Old 21st April 2012, 01:19 PM   #178
Here it is.
Old 21st April 2012, 01:25 PM   #179
Yeah, I plan to run lower voltage rails like 12-15V. Have to simulate distortion first.
Old 21st April 2012, 01:42 PM   #180
Tell me when you got it working. It sounds very good and worked right away. No problem with offset and bias. It runs quite high on cass a though, cool it well.
TSSA - The Simplest Symmetrical AmplifierHide this!Advertise here!
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
