#161 |
diyAudio Chief Moderator
So if we don't want auto protection extra circuits maybe it can be done to switch manually the delay thing, or double it as a remote main bias ''on'' from standby, using a far away preamp?
#162 | |
+ 12 V trigger signals from preamp or HT system via remote connector, turn on power supply's soft-start circuit, which is the different thing. Trigger signal puts on the whole amp from stand-by mode to on mode. After that sequence is done and if everything is OK, protection circuit sends internal 12 V remote signal to amp's PCB to turn output power transistors on.
#163 | |
now you can make it as dual mono power amp. I hope the sch mods can be implemented to existing PCB. |
#164 | |
Hi LC i take note from you modification a will work today later on for routing
Marc
website : http://audiyofield.wifeo.com/index.php |
#165 | |
![]() But I don't suggest to eliminate TLP from the PCB, since than you would have to send high Z loop 3,5 mA sensitive current signal across the long wires. Not recommended. There's always some spare DC potential to turn TLP on, just adjust serial resistor for higher/lower voltages drive signal.
#166 |
#167 | |
Marc
#168 | |
Marc
#169 |
#170 |
LC could you take a look at the schematic i attached. The ground i split in to that joining at one point. Is the ground point repartition silly or Ok.
Marc
| simplest amplifier possible with BJT's? | rmgvs | Solid State | 123 | 10th July 2008 03:05 AM |
| Symmetrical Phono Amplifier | seroxatmad | Solid State | 3 | 6th August 2007 04:00 PM |
| Simplest class B Amplifier | PicancoNet | Solid State | 42 | 8th June 2005 02:55 PM |
| Symmetrical amplifier conundrum | Kilentra | Solid State | 22 | 31st January 2003 05:06 AM |
| Symmetrical 400W amplifier | Diogo | Solid State | 30 | 28th October 2002 11:00 AM |
