#141 |
#142 |
LED is intended to be PS +/-50 V indicator not a room ambient light, which blue LEDs at If=20 mA quickly become.So 5 mA will be more than enough (see diagram) to do the indicating job properly and certainly we don't want two resistor-heaters on PCB just to feed the indicator LEDs - nonsense.
#143 |
New progression....
website : http://audiyofield.wifeo.com/index.php |
#144 |
May be not....
#145 | |
Marc
#146 |
Here with half led resistor
#147 |
#148 | |
Marc Note : 0R22 MPC71 and 2N5486/2N5462 are ordered
website : http://audiyofield.wifeo.com/index.php Last edited by Idefixes; 19th April 2012 at 07:58 PM. |
#149 |
Minor changes, more or less aesthetical ones:
- yes, MUR460 are as big as 2 W resistor, correct size as now - wire jumpers of correct lenght, aligned to grid with resistors - 1 mF and 2,2 mF have a little more space around, not all producers have exactly the same diameter for given voltage - four 15 V zeners move to the side, to have more thicker output track, more current capability - feedback tracks conducts only mA, so no problem as they are thiner now - parts alignment to drawn grid lines is now OK Until now I didn't make any connections check according to sch, that job will be performed when you'll make this final correction. ![]() Regards, Andrej P.S. For VAS 2SA/2SC transistors you can use Fischer heatsinks SK75 37,5 x 32 x 14 mm with two soldering pins for fixation and GND connection
#150 |
Thanks LC i go on work to evolution. I drawn schematic under eagle and than switch to board. At ths level without any componant placement Eagle present thin yellow line between components pins according connection drawned in schematic. When you done modification in schematic it affect board....Consequence is that normaly there is no mistake in connection if schematic is correct and if parts library are right, but even that i check every time the roting job accordig schematic.
| simplest amplifier possible with BJT's? | rmgvs | Solid State | 123 | 10th July 2008 03:05 AM |
| Symmetrical Phono Amplifier | seroxatmad | Solid State | 3 | 6th August 2007 04:00 PM |
| Simplest class B Amplifier | PicancoNet | Solid State | 42 | 8th June 2005 02:55 PM |
| Symmetrical amplifier conundrum | Kilentra | Solid State | 22 | 31st January 2003 05:06 AM |
| Symmetrical 400W amplifier | Diogo | Solid State | 30 | 28th October 2002 11:00 AM |
