TSSA - The Simplest Symmetrical Amplifier
Old 10th September 2015, 06:38 PM   #1481
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
Abetir, nice looking case
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 10th September 2015, 09:58 PM   #1482
de Ocampo is offline de Ocampo  Philippines
de Ocampo's Avatar
Thanks bwaslo
Originally Posted by sonnya View Post
The basic circuit relies on high class A current. So to perform just decent it should operate at atleast 2A idle ... So rising the voltage to 40v means a lot of heat. Also the arrangement with collector into base of the output device with no basis to emitter Resistor to turn the power transistors fast off would mean slow turn of as soon as it leaves class A.
My tssa v2 to V8 is a lot more complex to keep it all running as you already had figured out. But Then it is possible to run it In class AB without sacrisfying Performance
Sent from my iPhone using Tapatalk
If it's going to operate at 2A idle current the heatsink cannot hold that much heat generated , this is the reason why I avoided Class A but I'd like to try my hands on point to point wiring but not on a Class A
Thanks Sonnya
Old 2nd October 2015, 02:50 AM   #1483
Oland is offline Oland  Czech Republic
Default SEE
As to you such solution!
Old 7th October 2015, 07:17 PM   #1484
Racept is offline Racept
Default Fully symmetrical amplifier
Good day folks so I am currently looking for information on a fully symmetrical amplifier. Attached is the topology that i am focusing on. All I have is the topology that was given to me and i am getting difficulties in finding the book where it was taken from, could anyone assist me?
Thanking you in advance!
http://www.diyaudio.com/forums/attac...1&d=1444245430
Old 7th October 2015, 07:42 PM   #1485
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Hi
Symmetrical topology you are exploring is VFA which is not preferred in this thread. TSSA is CFA in CF output's configuration ie. voltage driven CCS. I would kindly ask if you can please proceed to find help in some other threads. Thanks for understanding.
Regards, L.C.
Old 7th October 2015, 11:54 PM   #1486
ostripper is offline ostripper  United States
ostripper's Avatar
May I suggest #7 - here - Slewmaster - CFA vs. VFA "Rumble"
You might also want to reference - Leach Amp Plans - Part 1 "leachamp" = #7 (spooky) ....
OS
Wanderer - my travels.... Facebook - davyjones lockre -
Old 25th December 2017, 09:38 PM   #1487
maxente is offline maxente  Romania
maxente's Avatar
Idefixes, any updates from this amplifier ?
Is it working ?
Old 10th July 2018, 05:35 AM   #1488
The Prof is offline The Prof  United Kingdom
Dormant ??
TSSA - The Simplest Symmetrical AmplifierHide this!Advertise here!
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
