TSSA - The Simplest Symmetrical Amplifier
Old 6th July 2014, 09:42 PM   #1471
platon.rado is offline platon.rado  Slovakia
Transistors 2N I gave to Scheme.Try and see
Thanks Marc
PS-when you look at it ???
Old 6th July 2014, 09:49 PM   #1472
Idefixes is offline Idefixes  France
Idefixes's Avatar
Send a message via ICQ to Idefixes
Thanks Marc
Yes i take a look allready and allready modify my eagle file. Give my your mail by MP or send me a mail i neither have yours.
Marc
website : http://audiyofield.wifeo.com/index.php
Old 6th July 2014, 10:00 PM   #1473
ok..send mail now.
Old 6th July 2014, 10:07 PM   #1474
Idefixes's Avatar
ok..send mail now.
Me too...
Marc
Old 5th August 2014, 08:44 PM   #1475
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Something's telling me we'll see some progress here soon.
Old 8th August 2014, 05:48 AM   #1476
lawbadman is offline lawbadman  Jamaica
lawbadman's Avatar
Can I use MJL4281A and MJL4302A in the TSSA amp? I have many of them doing nothing so I want to put them to good use.
Is 4 ohm operation ok for the TSSA?
<a href="http://www.danasoft.com"><img src="http://www.danasoft.com/sig/lawbadman.jpg" border="0"></a><div style="font-family:arial,sans-serif;font-size:11px;"><p>Sign by Danasoft - <a href="http://www.danasoft.com">For Backgrounds and Layouts</a></p></div>
Old 9th August 2014, 07:02 AM   #1477
Lazy Cat's Avatar
Yes, these outputs are OK. 4 Ohm load is easy to drive with TSSA so you're good to go.
Old 10th September 2015, 01:22 PM   #1478
de Ocampo is offline de Ocampo  Philippines
de Ocampo's Avatar
Originally Posted by Ripcord View Post
I finished my little TSSA BJT amp. There are so few parts I probably could of done it P to P but I've been trying to get better at laying out and making pcb'. It sounds pretty good. I'm using 2SC5200/2SA1943 output trans. My power supply is pretty standard, unregulated, 20,000uF per rail, 200va transformer.
Will this amp also handle a little over +-40vdc rail? I'd like to try it-out P2P and house it on this Tube like chassis that I built out of recycled materials. I could replace the BC550C/560C with the higher power BC556B/546B. Any other values that needs adjusting?
Many Thanks!
Old 10th September 2015, 07:09 PM   #1479
Ripcord is offline Ripcord  United States
Ripcord's Avatar
I'm hoping someone more knowledgeable will jump in here. I'm just not sure. I think the purpose of that circuit schematic was to show how simple the TSSA can be but would probably need some support parts to beef it up with higher rails and bigger wattage. Good luck.
Old 10th September 2015, 07:28 PM   #1480
sonnya is offline sonnya  Denmark
sonnya's Avatar
The basic circuit relies on high class A current. So to perform just decent it should operate at atleast 2A idle ... So rising the voltage to 40v means a lot of heat. Also the arrangement with collector into base of the output device with no basis to emitter Resistor to turn the power transistors fast off would mean slow turn of as soon as it leaves class A.
My tssa v2 to V8 is a lot more complex to keep it all running as you already had figured out. But Then it is possible to run it In class AB without sacrisfying Performance
Sent from my iPhone using Tapatalk
Mirand Audio amps and Dac's - http://mirand-audio.dk/?post_type=product
TSSA - The Simplest Symmetrical AmplifierHide this!Advertise here!
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 04:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 05:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 03:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 06:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 12:00 PM
