#1431 |
diyAudio Chief Moderator
#1432 |
Location: Scottish Borders - Kelso; on the famous Tweed River!
Yes please!
Thanks, Brian |
#1433 |
#1434 |
This is an excellent amplifier and deserves an excellent chassis!
Depending on the cost, very interested.
"Without deviations from the norm, progress is not possible" - Frank Zappa |
#1435 |
I hesitate to post this because I'm not sure if it's good or not. I've included three attachments. One of the Lazy Cat TSSA BJT circuit, second, of my pcb layout with component values and third, my pcb layout without component values. I layed out the pcb's in a program called DIYLayout Creator. I've been using it a lot for simple guitar stompboxes and small power amps. I know that I should just bite the bullet and learn Cadsoft Eagle. I was hoping someone could take a quick look and see where the glaring errors are or if I should just scrap the whole thing and use a better pcb editor. I've seen the layouts that Ales MM and a few other do here and there so good. (Beyond good). I just wanted to etch my own all bjt version of the TSSA and listen to it. You won't hurt my feelings if it stinks.
Tom |
#1436 | |
#1437 |
Hi All.
I have made an powersupply design guide. I know it is based on my modules but, I have added comment about fuse and wire dimensions. I hope it is useful. - Sonny |
| simplest amplifier possible with BJT's? | rmgvs | Solid State | 123 | 10th July 2008 03:05 AM |
| Symmetrical Phono Amplifier | seroxatmad | Solid State | 3 | 6th August 2007 04:00 PM |
| Simplest class B Amplifier | PicancoNet | Solid State | 42 | 8th June 2005 02:55 PM |
| Symmetrical amplifier conundrum | Kilentra | Solid State | 22 | 31st January 2003 05:06 AM |
| Symmetrical 400W amplifier | Diogo | Solid State | 30 | 28th October 2002 11:00 AM |
