Old 4th December 2012, 09:54 PM   #1401
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by sonnya View Post
No it is not. It works very well. My protoamp has run for months with this configuration.
No need to worry.
By using 50R you do not lose feedback. Distortion is the same. Damping factor is the same.
Being a CFB amp, only the 1K Rf position changes the current injection to the input node so the voltage gain division ratio does not modify crucial parameters? Is that a right way to sum it up?
Old 4th December 2012, 10:03 PM   #1402
sonnya is offline sonnya  Denmark
sonnya's Avatar
More or less.
Old 4th December 2012, 10:06 PM   #1403
Salas's Avatar
OK, clear. Thanx.
Old 4th December 2012, 10:09 PM   #1404
Esperado's Avatar
How is-it possible, while feedback is divided by 2 ?
Christophe.
Ultimate Protection
Old 4th December 2012, 10:19 PM   #1405
sonnya's Avatar
i will write up on this one tomorrow Cristophe.
R11 and C12 sets the bandwidth and R11 and R12 is an "emitter" resistor at lower frequencies.
By set emitter to 50R instead of 100R we raise the open loop gain by +6dB but at the same time we increases the closedloop gain by +6dB. => loopgain is untouched.
Old 6th January 2013, 09:08 AM   #1406
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Hi Sonny,
one question, can we increase input impedance and if if yes, up to what value? Are there going to be any drawbacks to this?
If possible, it is going to be very helpful to my setup.
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 6th January 2013, 10:59 AM   #1407
Send a message via Yahoo to mikelm
i will write up on this one tomorrow Cristophe . . .
Tomorrow never came
. . . . . . . . . . . . . . . . oOo . . . . . . . . . . . . . . . . . .
Best to assume that everything makes a difference
Old 6th January 2013, 11:11 AM   #1408
sonnya's Avatar
Originally Posted by mikelm View Post
Tomorrow never came
Sorry.. We have just been to busy.
We work 7 days a week. Have hired an engineer and an assembly lady. Will maybe need a Technician also.....
Old 6th January 2013, 11:13 AM   #1409
sonnya's Avatar
Originally Posted by vgeorge View Post
Hi Sonny,
You could change R1 to 22 - 100K only there will be a offset step when you connect/unconnect you source.
Old 6th January 2013, 11:52 AM   #1410
vgeorge's Avatar
That means no problem, as I never connect/unconnect live my sources.
Thanks Sonny.
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
Copyright ©1999-2013 diyAudio
