TSSA - The Simplest Symmetrical Amplifier - Page 140 - diyAudio
Old 4th December 2012, 08:58 PM   #1391
sonnya is offline sonnya  Denmark
sonnya's Avatar
Originally Posted by Esperado View Post
Can't you add a // cap with the feedback resistance to keep the closed loop bandwitch the same ??
For the quiescent, my amp use a ccs referenced to rail, so we are not in the same situation, you are right.
If it is okay, you can show me the circuit. Just so that i can follow you.
Old 4th December 2012, 09:00 PM   #1392
sonnya's Avatar
No as with rising frequence the cap will start act as a smaller Rf. And it currentfeedback this oscillation will start
Old 4th December 2012, 09:02 PM   #1393
Banned
Where is your schematic, for i can be more accurate ?
I know this amp is very sensible and each pole change can have a lot of consequences...
Old 4th December 2012, 09:04 PM   #1394
sonnya's Avatar
http://sitosite.dk/amps/TSSA-01300712.pdf
Old 4th December 2012, 09:17 PM   #1395
Banned
Well, i understand better your choice, now. I would try a 2K for R11 - R12 and a little paralleled cap with it for stability and no overshoot on square waves, if possible.
The thing i worry, looking at your schematic is the one octave upper high pass filter frequency if we decrease the R13 -R14 from 100 to 50, right ?
You have better experience on it, anyway... I suppose you have tried near everything ?
Old 4th December 2012, 09:25 PM   #1396
sonnya's Avatar
You are right. I remembered wrong. It is 47pF millercaps. Withe 33pF we starts to have small signs of oscillation driving capacitive loads.
Old 4th December 2012, 09:28 PM   #1397
sonnya's Avatar
There is always something new to try.
My problem is that my time flyes away. Right now i am doing a stepup LED driver for a new display for a customer as the OLD display was EOL!!! It is 23:37 .. stupid stupid .. When you can make audio instead....
Old 4th December 2012, 09:36 PM   #1398
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
So to put it in a nutshell, is George's move to go 50 Ohm +6dB worsening the stability or THD spec or does something else negative? He loses 6dB feedback and some damping factor is one thing I would suppose, but he drives a 20 Ohm+ load.
Old 4th December 2012, 09:41 PM   #1399
sonnya's Avatar
No it is not. It works very well. My protoamp has run for months with this configuration.
No need to worry.
By using 50R you do not lose feedback. Distortion is the same. Damping factor is the same.
Old 4th December 2012, 09:48 PM   #1400
sonnya's Avatar
No need to worry.
You have to focus on the RF (R11 and R12) combined with the millercaps (C12 and C13).
They set the bandwidth. Do not place a cap across R11 and R12 . It will oscillate right away with a capacitive load.
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
Copyright 1999-2017 diyAudio
