TSSA - The Simplest Symmetrical Amplifier
Old 4th December 2012, 04:00 PM   #1381
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
From 100R to 50R when talking the ground return Fb ones for +6dB?
Old 4th December 2012, 04:11 PM   #1382
Esperado is offline Esperado  France
Banned
Two important points. Don't forget that, in a CFB amp, changing the serial feedback resistance value will change the slew rate. Changing the emitter resistance value will change the current in the input transistors.
So if you want to add some gain, the best is to replace the serial resistances by an attenuator, keeping the impedance seen by the input transistor near the same.
By example, if your original serial resistance is 1K and the emitter 50 Ohms, from the output, do 1Kserial +1k to gound and 500 Ohm to the 50Ohm.
Old 4th December 2012, 04:31 PM   #1383
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Yes, these ones.
Sonny supplied both values with the kit.
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 4th December 2012, 07:49 PM   #1384
sonnya is offline sonnya  Denmark
sonnya's Avatar
Hi Esperado.
With a reasonable bandwidth, reducing the emitter resistor will not cause any high currents in the audio range. But i have and will recommend any one to have a lowpass input filter.
For two reasons:
  1. Reduce emi from the line signal - cellphones in particular
  2. Reduce slewrate allowed even if the amp is capable of more. It stresses the transistor and zobel network a lot with "extreme" slewrates.
By leaving the Rf value and reducing the emitter resistor you will raise the loop gain... So by adding +6dB system gain, this way the loopgain stays the same.
Old 4th December 2012, 07:59 PM   #1385
sonnya's Avatar
The 200kHZ square waves pics are with no bypasses at all. Not on rails, not on feedback. Perfectly stable. I don't know if the bypasses speed it up more, but with just the FC lytics, I found the -3dB point at circa 2.5MHZ (6 vertical divisions reduced to 4 rough check point).
I will maybe change the DOC to say that they should start out without the bypass caps in the feedback network.
They can always add them later.
Old 4th December 2012, 08:05 PM   #1386
Banned
Originally Posted by sonnya View Post
HWith a reasonable bandwidth, reducing the emitter resistor will not cause any high currents in the audio range. But i have and will recommend any one to have a lowpass input filter.
I too, of course. But keeping the ratio signal speed/amp speed as little as possible is the target. If no stability issue, i would reduce the serial feedback resistance instead. Keeping a low-pass filter at 200Khz before the input.
Old 4th December 2012, 08:29 PM   #1387
Banned
May-be i need to precise my point. Decreasing the emitter resistance of the first stage will increase the gain of the input stage, as its collector one will stay the same. If the amp has been carefully designed for each stage produce the same distortion in open loop, you will increase-it. And the quiescent current will be increased as well. Right ?
That's why i recommended to not touch this resistance.
On the contrary, reducing the serial feed-back resistance will stay the input stage unchanged, and reduce the influence of parasitic influence near the emitter of the input transistor because impedance will be reduced.
Old 4th December 2012, 08:34 PM   #1388
sonnya's Avatar
Agree. I tried that too. But then millercaps should be larger.
That was what real life tests showed.
Secondly its thermal stability gets worse when Rf was reduced. Not as bad as is the SSA design.
2.3mV/K across 1K instead of 100R in the SSA. That is a 10 factor.
Old 4th December 2012, 08:39 PM   #1389
sonnya's Avatar
No the quiescent current will not increase, It is controlled by the current source and Rf. The emitter resistor is AC coupled to GND.
That is correct but you will raise the bandwidth. And my test showed that this is NOGO . 33pF and Rf=1K is the limit. Reducing Rf means larger Millercaps ....
Old 4th December 2012, 08:52 PM   #1390
Banned
Can't you add a // cap with the feedback resistance to keep the closed loop bandwitch the same ??
For the quiescent, my amp use a ccs referenced to rail, so we are not in the same situation, you are right.
TSSA - The Simplest Symmetrical AmplifierHide this!Advertise here!
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
