TSSA - The Simplest Symmetrical Amplifier
Old 3rd December 2012, 03:24 PM   #1371
Samuel Jayaraj is offline Samuel Jayaraj  India
Other than the TLP627, I have everything in my large parts collection; JFETs are similar, eg., 2N5461 instead of 5462. So will a PDF of the track pattern be made available please? Thanks.
Sam
Old 3rd December 2012, 05:07 PM   #1372
Jay is offline Jay  Indonesia
Banned
Originally Posted by Idefixes View Post
TLP627 is opto device remoted by DC detection on OUTput. The whole effect is to shutdown output stage when DC is present.
The design is not fully tested for moment (missing time). Before etching plate are you shure to be able to purchase all matched need transistor in BIGBT module (NPN/PNP and mosfet) but all little and middle transistors too in first stage?
Marc
What?
Old 3rd December 2012, 06:44 PM   #1373
Idefixes is offline Idefixes  France
Idefixes's Avatar
Send a message via ICQ to Idefixes
Originally Posted by Jay View Post
What?
What, What????
website : http://audiyofield.wifeo.com/index.php
Old 3rd December 2012, 06:47 PM   #1374
Idefixes's Avatar
May be in private but at your own risk as i don't want to publish something public that not be tested
Marc
Old 4th December 2012, 10:04 AM   #1375
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Hi Samuel
2N5461 is conditionally acceptable because it could have too low Vgs at demanded CCS current, so cascoded BJT's Vce=Vgs would not have enough headroom to operate properly. I suggest you to use 2N5462 or two 2N5461 in parallel.
Old 4th December 2012, 12:39 PM   #1376
Originally Posted by Lazy Cat View Post
Hi Samuel
Thanks for that info. Might as well order for 2N5462 from Element14 (formerly Farnell) as well as all the JFETs required for Sonya's version of the TSSA.
Sam
Old 4th December 2012, 02:32 PM   #1377
sonnya is offline sonnya  Denmark
sonnya's Avatar
Originally Posted by vgeorge View Post
Try to listen with the feedback bypass caps completely removed first.
From stability point of view it is okay as Rf is not alteret.
How do you describe the Sound after some days og use?
What about salas? What do you Think ?
Old 4th December 2012, 02:43 PM   #1378
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
The 200kHZ square waves pics are with no bypasses at all. Not on rails, not on feedback. Perfectly stable. I don't know if the bypasses speed it up more, but with just the FC lytics, I found the -3dB point at circa 2.5MHZ (6 vertical divisions reduced to 4 rough check point).
Old 4th December 2012, 03:10 PM   #1379
Esperado is offline Esperado  France
Banned
I believe it is better that way: a light low pass filter induced by the lytic inductance is better than any ringing.
And, as long open loop bandwidth and slew rate remains unchanged, we don't need zillion htz of closed loop bandwidth.
Old 4th December 2012, 03:55 PM   #1380
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Sound is really nice, I think the best amp ever listened.
Changed the feedback resistors to 50R from 100R to have a little bit more gain. Seems better on the lower gain but I am not sure. Maybe try with 75R and see.
"Without deviations from the norm, progress is not possible" - Frank Zappa
TSSA - The Simplest Symmetrical AmplifierHide this!Advertise here!
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
