TSSA - The Simplest Symmetrical Amplifier
Old 22nd November 2012, 09:47 PM   #1321
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
It's more like NTC's internal temp peak for 0,7 s at SSA soft start, on outside one can hardly notice a temp rise.
No I'm sorry I didn't try any stabilized power supply for front-end or output at SSA. I had my MonoLith amps with front-end stabilized and regulated but my later designs works fine with just regular general smoothing. I found a lot more sense in separate ciruit sections to have near perfect local DC voltages, currents, etc. I look to general power supply more like as a mains power, enabling low Z, the rest is on certain circuit points.
BTW I sold NC400 monoblocks to one class D fan and he said that they're better than NuForce's monoblocks.
Old 22nd November 2012, 09:58 PM   #1322
Esperado is offline Esperado  France
Banned
I Don't like supplies with feedback loop, but i always found real improvements with simple ballast (zener at base) for the power stages, even if the previous ones where totally stabilized and regulated.
Why not try-it once, it is not complicated.
Old 2nd December 2012, 08:44 AM   #1323
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Some TSSA reporting in the middle of this linked post amongst other things
Old 2nd December 2012, 09:52 AM   #1324
Banned
What a review !
Old 2nd December 2012, 10:07 AM   #1325
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
Salas: Thank you for the link. I agree with all positive comment on your photo-journalism. Well done and thank you.
Old 2nd December 2012, 07:20 PM   #1326
Lazy Cat's Avatar
Hi Salas
It's nice to see the insight of such beautiful DIY audio session as you thoughtfully prepared it. All predominating factors were measured and evaluated to be sure that everything is electrically OK before starting the test. As expected TSSA (Sonny's version) proved to be competitive enough to play its important role in the presented system. For this thread I choosen four pics as I think they can be very appealing for someone potentially deciding which amp to build.
Old 2nd December 2012, 08:51 PM   #1327
Salas's Avatar
The MKP caps positions across the feedback electrolytics were tried out and soon abandoned for they introduced some brightness in that system, I may add.
Old 2nd December 2012, 09:29 PM   #1328
Banned
Not surprising.You have good ears ;-)
Old 2nd December 2012, 09:30 PM   #1329
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
.......... they introduced some brightness in that system, I may add.
sounds familiar
Old 2nd December 2012, 09:58 PM   #1330
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
try adding 1uF - 4.7uF with 0.2R in series instead - it sounds much better
TSSA - The Simplest Symmetrical AmplifierHide this!Advertise here!
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
