TSSA - The Simplest Symmetrical Amplifier
Old 7th October 2012, 05:16 PM   #1261
Esperado is offline Esperado  France
Banned
Originally Posted by Esperado View Post
L.C., i would like to have you sentiment about this idea (May-be it was yet in your head ?) to have two different output stages technology (BJT, FETs) with the same previous stages ?
To make the things more clear, i believe between all SSA combinations, this had not be tested yet:
I presume it would need some little changes of the temp compensation in the previous stage.
Old 7th October 2012, 05:51 PM   #1262
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
I thought about it too but never tried all mosfet triple like BIGBT. This configuration would be nice to settle with exactly 50% of current splitting between the output mosfets. First Rgs could be trimmers and after finding the value to exactly split the current, can be replace by fixed resistors. The only problem would be loosing quite a portion of output amplitude in regarding to double Vgs value from the rails. Clipping can be around 5 V below the rail potential, lower efficiency in compare to regular emitter follower.
Also as you already mentioned BJT and mosfet outputs could be easily swapped to check sound signature of certain configuration or just because experimenting to find best sounding solution.
Old 7th October 2012, 06:06 PM   #1263
Jay is offline Jay  Indonesia
Banned
Is it possible??? The hexfet needs to be biased with sufficient current while the latfet needs sufficient Vgs to conduct. Seems impossible to achieve at the same time
Old 7th October 2012, 06:36 PM   #1264
Lazy Cat's Avatar
Many things possible, especially if you try it in practice. I think YES it is.
Mosfet driver would practically operate at constant Id, its Rds will change just to sustain constant voltage drop on Rgs resistors.
Old 7th October 2012, 07:19 PM   #1265
Idefixes is offline Idefixes  France
Idefixes's Avatar
Send a message via ICQ to Idefixes
Today i complet at 98% the soft-start/speaker protection board, so i can go foward with CSS testing in TSSA BIGBT HP. The speaker protection wil drive the TLP627 on amp board
website : http://audiyofield.wifeo.com/index.php
Old 7th October 2012, 07:49 PM   #1266
Banned
Right, but no problem to provide separate power rails, isn't it ?
Anyway, for experimenting, it will not be a great difference in listening level, with rails >50V. Just power numbers.
An opportunity for Nico Ras to share with us with minimal work more experiences about the sound signature of power devices, BJT, Hex FETs, MOSFETs and try different combinations of them. ;-)
I will try to find some times and courage in next months to explore that too, it really tease-me... I use to prefer the sound of power Hexfets, but this is far to be "scientific" as so many things differed in my comparison's amps.
Can be simulated too, to see if any obvious difference in virtual measurements and save time to eliminate some combinations...
Agree. Not to forget we can play too with gate stoppers and, as you mention, Gate/Source resistances values of the driver.
Old 9th October 2012, 04:02 AM   #1267
Banned
Tried quickly to sym the idea, both with BJT and FET drivers.
It makes a very efficient modulated oscillator. Driver not fast enough wuth the part i used: The collector/drain of the driver, goes the wrong way (pushed by the hp V) during the transient of square waves.
Bad good idea ?
Old 9th October 2012, 06:27 AM   #1268
Lazy Cat's Avatar
Dear ersa191
In a glorious spirit of enthusiasm you have made a great leap forward but maybe just a little too fast, so now I only can please you to wait for Idefixes to test the prototype for functionality and than you will both cross the finish line simultaneously.
P.S. ... to ersa's post which vanished ehhehehe
Old 9th October 2012, 06:30 AM   #1269
sonnya is offline sonnya  Denmark
sonnya's Avatar
Bad good idea ?
Which part of the circuit?
Old 9th October 2012, 06:33 AM   #1270
Lazy Cat's Avatar
Bad good idea ?
At which frequency?
TSSA - The Simplest Symmetrical AmplifierHide this!Advertise here!
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
