TSSA - The Simplest Symmetrical Amplifier
Old 7th October 2012, 09:22 AM   #1251
Idefixes is offline Idefixes  France
Idefixes's Avatar
Send a message via ICQ to Idefixes
Since there is some interest by other people on TSSA BIGBT HP i think i will open a new thread on it to easier informations.
Marc
website : http://audiyofield.wifeo.com/index.php
Old 7th October 2012, 09:28 AM   #1252
Harry3 is offline Harry3  Australia
That's great.
Please include your capacitor dimensions as I am currently trying to find parts.
Old 7th October 2012, 09:41 AM   #1253
Idefixes's Avatar
Originally Posted by Harry3 View Post
That's great.
May be if there is a real interest i will write i bom with references.
Marc
Old 7th October 2012, 10:50 AM   #1254
Lazy Cat is online now Lazy Cat  Slovenia
Lazy Cat's Avatar
Originally Posted by AKSA View Post
Bonjour Christophe,
Thank you for your reply.
I have carefully listened to this configuration - not measured rather, but critically listened only - and found an impression of harshness. You could expect this however since any distortion of mixed npn/pnp on each side would add additional on each half cycle, which in turn shows odd harmonics.
OTOH if you adopt npn and pnp asymmetrical for the outputs, viz the usually approach for most amps, you have undifferentiation transconductance, which indicate pushes towards to even distortions, most H2.
You have to choose whether you prefer very low distortion of H3/H5 or highish distortion of H2/H4. That depends which presentation you prefer look like, and you might even ask if the very odd harmonics are audible regardless the very vanishingly THD.
Your choose your poison.......
Ciao,
Hugh
Bonjour Hugh
Welcome back to DIY company, wish you great time and lots of new amp designs.
As we all know distortion profile changes its higer harmonics amplitude structure due to many factors, one of them is bias current of the output transistors/drivers. To find optimal setting, sweet spot, one doesn't need sophisticated analysing equipment, can in most cases also quite firmly rely to sound signature of presented material.
BIGBT is new only in using mosfet as driver as told by me many times, and that I see as advantage compared to BJT driver. Proper gain matching and biasing makes this triple a wining solution for an output stage.
Now we have ideal case of Idefixes building new TSSA BIGBT HP and he could tell us than his impressions comparing to other amps he owns.
We here found SSA BIGBT HP sound signature to be very cultivated, musical and full of details, compared to other factory made beasts.
Kind regards to Hugh and all
Old 7th October 2012, 11:20 AM   #1255
Lazy Cat's Avatar
Originally Posted by Idefixes View Post
So here are start step, i soldered parts LC indicate me. These parts form the 3 CCS.
Hi Marc
According to red circles marked on TSSA BIGBT HP sch make following steps:
- connect +OUT pin to GND pin
- rotate VR2, VR3 to max resistance
- connect power supply +/-50 V and GND to proper PCB pins
- turn VR2, VR3 in a way that you measure 25 V voltage drop on R12, R21
- connect 9 V battery to J3-1, J3-2 and set value of R26 to get 37,5 V voltage drop on R4, R6
- check voltage drop on C6, C7, have to be app. 2 V each
- check voltage drop on VR1, VR4 TL431, it should be 2,5 V in both cases
- check voltage drop between pin 3,4 of TLP627, it should be around 0,2 V
- all five LEDs should lit too
By executing this procedure you have settled current sources/sinks to proper values.
Old 7th October 2012, 12:12 PM   #1256
Idefixes's Avatar
Originally Posted by Lazy Cat View Post
Hi Marc
Hi LC,
Connections as you indicate are not yet made. They are easy as i just have to plug fuse in socket and made a cable jumper between out facton pin and gnd faston pin.
For TLP627 supply i have on my soft-start/ speaker protection board a 0-12Vdc extra out-put that i can use just by cable connecting.
I am on wrinting a new topic on TSSA BIGBT HP building we will continue further step overthere if you are aware for more clarity.
Marc
Old 7th October 2012, 12:26 PM   #1257
Esperado is offline Esperado  France
Banned
You have to choose whether you prefer very low distortion of H3/H5 or highish distortion of H2/H4. Your choose your poison.....
I prefer as less distortion as possible. :-)
I don't see where this configuration can add distortion, comparing to a pure NPN or pure PNP half amplifier: i believe the only effect will be to slightly reduce even distortion because the symmetry of the two half waves.
If NPN and PNP are different in distortion, they will add their own by a x 0.5 factor because they are paralleled. So it is supposed to reduce by 2 odd distortions in the same time.
The FET driver add some more advantages, i think.
First FETS are usually faster and will not add a pole too close to the NPN/PNP's one.
Second, it is more linear, (less odd distortion). It do not require polarization (only for fixing the quiescent current) and react more like a pure resistance, while NPN/PNP behave more like a Voltage source. And they are hight impedance: better isolation with the previous stages.
Third, the parasitic gate/source capacitance will not have all its inconvenience here, because the current across-it will be added to the signal at the base of one of the output device.
Fourth, if we use Lateral MOSFETS, baecuse their negative temp factor, they will (partially ?) compensate the temp factor of the NPN/PNP device.
Comparing to the Bryston amps, we are in a totally different world, because Current feedback. And here, the huge open loop bandwidth of the amp will reduce high order distortions as well as prevent from TIM. I think the musical signature will be totally different.
With CFB, global loop is a bonus, with no negative effects.
Last, if you agree that there is not so much disparities between NPN and PNP devices, once paired, so not so much difference with a conventional schematic with BJT devices, the advantages of this configuration will be obvious with FETS where gate/source capacitances are impossible to match.
L.C., i would like to have you sentiment about this idea (May-be it was yet in your head ?) to have two different output stages technology (BJT, FETs) with the same previous stages ?
Old 7th October 2012, 12:32 PM   #1258
Idefixes's Avatar
That' my case ; all bjt and fet are matched
Marc
Old 7th October 2012, 01:24 PM   #1259
Lazy Cat's Avatar
Hi LC,
OK, yes all necessary connections have to be made to power up the LEDs and CCSs.
Marc
Can you please postpone new thread until we make the amp running as planed. When it will work properly, than yes start a thread to inform the others about your amp.
Old 7th October 2012, 01:48 PM   #1260
Idefixes's Avatar
Ok i just summing informations (advices, schema, apprairing process..)by side in word format.
Marc
TSSA - The Simplest Symmetrical AmplifierHide this!Advertise here!
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 04:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 05:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 03:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 06:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 12:00 PM
Copyright ©1999-2017 diyAudio
