Old 30th September 2012, 08:10 PM   #1191
sonnya is offline sonnya  Denmark
sonnya's Avatar
Or even more fun. What if it could be a single cfb opamp dropin??
Old 1st October 2012, 08:14 AM   #1192
Lazy Cat's Avatar
Originally Posted by sonnya View Post
I am thinking of doing a 2 stage tssa preamp.
What should max gain be ? 6 or 12 dB??!
Make both, jumper selectable.
What? You'll compete with Bursons?
Old 1st October 2012, 08:36 AM   #1193
sonnya's Avatar
I do not think Bursons sell them any more!?
By the way, i have made one before and it works very well besides of the offset in the PMBFJ620 which i did not see come....
Jfet folded cascode with diamond buffer opamp
With a little luck i can make a 2 stage CFB in the same space.
Old 1st October 2012, 08:45 AM   #1194
Lazy Cat's Avatar
WOW I didn't know what you did already. Amazing.
I would be the first to order few of these CFB OP amps.
Old 1st October 2012, 08:57 AM   #1195
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Sonny is our miniaturization wiz. Indispensable skills in new age electronics. We will end up with stereoscopes sooner or later to make a simple mod with the rate parts are shrinking.
Old 1st October 2012, 09:03 AM   #1196
sonnya's Avatar
Some quick calculations tell me that it will not be as compact as the "discrete opamp" i already have made.
I need to use SOT-223 package for the output devices.
Old 1st October 2012, 09:23 AM   #1197
sonnya's Avatar
It suffers the same problem as TSSA V1.6 -> high zout of ~60Ohm.
but 2Vpp input, 6dB gain and Load of 1K will give you 3,67Vpp out with THD of 0.000323% thd..
I do not think it is bad. See attachment...
Old 1st October 2012, 09:58 AM   #1198
Esperado's Avatar
So, it looks OK for a 10K load, witch respond at most frequent requirement in a preamp ?
And, as output stage in a preamp has to be an overkiller low Z headphone amp, for it can drive any capacitive load, easy to add a single buffer with discreet transistors, don't you think ?
What about the PSRR ? (I love the Nightly maintenance pictures :-)
Christophe.
Ultimate Protection
Old 1st October 2012, 11:02 AM   #1199
sonnya's Avatar
I think the PSRR is okay.
Distortion into 10K is a little higher but better roll off.
File Type: pdf cfb v20 opamp 011012 1KHz fft 10K load.pdf (152.6 KB, 35 views)
Old 1st October 2012, 11:08 AM   #1200
Jay is offline Jay  Indonesia
Suitable for headphone amp.
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
Copyright ©1999-2013 diyAudio
