TSSA - The Simplest Symmetrical Amplifier
Old 29th September 2012, 06:07 PM   #1181
Esperado is offline Esperado  France
Banned
Originally Posted by Lazy Cat View Post
Very nice circuit indeed.
Yes. And can be used to current limit a soft start.
Remains the second target: Regulate the V right at the Amp power transistor current source pin. (for transients consumption). My suggestion:
http://www.esperado.fr/images/temp/reg.jpg
The regulation parts can be on an other board. What seems a good idea to me is to have the power regulation device right on the Amp circuit. It will reduce to none the influence of the power wiring. and i'm sure we can reduce any caps at the regulated point to <= 1f, so, use film ones for no Hf limitation..
This power regulation transistor could be used too for instant protection in a very elegant way, adding no parasitic impedance in serial with power supply or loudspeakers. Just putting them in the nonconductive state.
Old 30th September 2012, 10:57 AM   #1182
Idefixes is offline Idefixes  France
Idefixes's Avatar
Send a message via ICQ to Idefixes
Hi LC,
You can prepare "TTSA BIGBT" procedure, i will etch new board this afternoon.
Marc
website : http://audiyofield.wifeo.com/index.php
Old 30th September 2012, 04:59 PM   #1183
Idefixes's Avatar
So here are the boards (TSSA BIGBT HP evo + soft start/speaker protection) and 2 shots of my diy etching procedure whith etching( H20/HCL/H2O2)/water/revalating solution(H2O/water)
Old 30th September 2012, 06:12 PM   #1184
Lazy Cat is online now Lazy Cat  Slovenia
Lazy Cat's Avatar
Originally Posted by Idefixes View Post
Hi LC,
Marc
Very good, all details prepared to bring new TSSA amp into life.
I asume that all necessary transistors are matched, so we can start with CCS-s only, to set correct constant current levels needed. There are three of them on one PCB, so this will be opening part of construction.
Regards Andrej
Old 30th September 2012, 06:30 PM   #1185
Idefixes's Avatar
Regards Andrej
I just have to mesure BC560 and BC550, all others are yet done.
Marc
Old 30th September 2012, 06:33 PM   #1186
Lazy Cat's Avatar
Many years ago, lets say around 20, I did the last PCB by etching. The same chemistry was used and I still remember the smell and bubbles from the process, and worries that the reaction would be to fast, to hot etc. But the moment of glory was there when PCB tracks appeared from the foggy bursting fluid reaction. Always happy moment when finished, brought a big smile to my face.
Old 30th September 2012, 06:48 PM   #1187
Idefixes's Avatar
I like this moment to...the pcb born after spending lot of time on computer to route project. The procedure is quite easys. I do it in front of garage door so no soucy with bad vapour...
Marc
Old 30th September 2012, 07:11 PM   #1188
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Idefixes,
What is your procedure for etching. Sometimes mine turns out great, others not so. I have never done two stage method.
...Shape the sound , Man!
Old 30th September 2012, 07:47 PM   #1189
Idefixes's Avatar
Originally Posted by buzzforb View Post
Idefixes,
So
- printing with laser printer on transparent paper named "papier calque" in french
- expose under UV fluo bulb about 150s on Bungard positf PCB
- revalating in mix of 20ml NaOh + 1L distilated water
- wash in fresh water
- etch in mix of 200ml distilated water + 100ml HCL + 100ml H2O2 (Give big warning to mix in the order i gave you above it can be dangerous if not). The time wil depend to Cu to dissolve on pcb. You must controle process.
- wash in fresh water.
Marc
Old 30th September 2012, 08:05 PM   #1190
sonnya is online now sonnya  Denmark
sonnya's Avatar
I am thinking of doing a 2 stage tssa preamp.
What should max gain be ? 6 or 12 dB??!
TSSA - The Simplest Symmetrical AmplifierHide this!Advertise here!
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
