Old 14th September 2012, 03:13 PM   #1151
dadod is offline dadod  Croatia
dadod's Avatar
Originally Posted by Joachim Gerhard View Post
Christophe, your bias spreader in your CFB Crescendo is 220 Ohm and when you bias the output correctly it will be even less. Your cascode VAS has a current output and the bias spreader will convert that into a voltage. In that sense you have a voltage drive due to Ohms law U = I x R so you could say you make an I/U conversion and current and voltage is interchangeable due to that formula as long as the VAS does not go out of steam current wise. The bias spreader resistor then forms a low pass with the input capaciatnce of the output stage. The lower the driving resistance the better you control the input capacitance of you MosFet output stage. On the other hand you have to roll off the open loop gain somewhere. In my preamp that is also a small lateral mosfet current feedback power amp with 2W class A i simply use the gate stoppers for that to form a low pass. The gate stoppers are arranged in such a way that the gate stopper to the P-Channel is somewhat smaller in value. I have not tried a miller cap or other options but it works just fine.
My simulation shows 70 ohm.
dado
Old 14th September 2012, 03:25 PM   #1152
Joachim Gerhard's Avatar
Then the VAS needs ample current drive capability.
Old 14th September 2012, 03:42 PM   #1153
dadod's Avatar
VAS runs at 13.5 mA in my simulation.
dado
Old 14th September 2012, 03:58 PM   #1154
Send a message via Yahoo to mikelm
Originally Posted by Esperado View Post
... That you can reduce to one, adding a soft start circuit.
One of the rare things i agree with audiophiles blind beliefs is the benefit to overkill the PSU current.
My 1100VA transformer +big caps are affraying, if directly plugged in sector: The Lights flicker in my home, and the noise in the transformer terrorize my dog
With soft start, everything runs smoothly, and i can hear my caps's thanks and look at their smiles during much more years.
Yes, a soft start would mean that potential resonances would not be excited at turn on and turn on would be less violent but I would still recommend that the choke regulation scheme is designed with sufficient damping so that there is not even a tendency for ringing. An underdamped scheme could give rise to the kind of oscillation problems that jayadev was referring to in the other thread.
I have the feeling Christophe that you regard me as an audiophile that likes to see hifi as mythical art that lies outside the realm of the physical sciences - actually nothing could be further from the truth. When I hear a comment like "valve circuits add some magic to the sound" it annoys me that some adopt this religious kind of an approach - my immediate question is what are the factors that are responsible for this perception ?
I always intend to follow good engineering principals when designing audio but I also accept that there are some things that might be very difficult to measure that we can hear subjectively so I allow my ears to inform my choices also.
Old 14th September 2012, 04:01 PM   #1155
Esperado's Avatar
I agree on that, of course. Just i do not agree this use of gate stopper as a low pass filter because gate capacitance is not dynamically linear.
Well, using 3 power FETs by rail would help a little to move the capacitance hole a little further out of the range, but that is not fully satisfying on an intellectual point of view.
Many DIYers had oscillations or overshoots problems, when they tried this amp, and i would not like to provide support :-)
Mine is OK after tuning, and sound well enough (the feedback work well enough to compensate the non linearities), so it will stay as-it, i'm a Lazy Dog.
This Crescendo was just a quick'n dirty mod, and, as i'm not so sure that spending a lot of time to improve the driver stage will change the sound in a drastic way. I prefer to spend this time listening music :-)
Again, this was just an example to demonstrate 3 things:
- How most of classical VFB amp can be modified in SSA, and tribute to this so clever symmetrical feedback returns, compensating the emitters offsets.
- How Current feedback can improve both numbers and listening pleasure.
- How Lazy Cat is a talented audio designer.
Looking deeply in the SSA details, my conclusion was that it is so nicely designed and accurately calculated everywhere that, if i had to build a new amp, i would not even try to calculate or simulate anything anymore: Just i would build-it as it, saving time and efforts. I'm not able to do better. And i have never seen a better amp elsewhere.
Christophe.
Ultimate Protection
Old 14th September 2012, 04:09 PM   #1156
After 1.89V the VAS will run out of class A. It will provide more current though or else the modified Crescendo would not reach it´s output power.
That does not say that this is an un linear amp, there is still the distortion reducing action of the feedback.
Old 14th September 2012, 04:11 PM   #1157
Again that tells me that in a 3 stage amp ( IPS, VAS, OPS ) the VAS caries the heavy lifting voltage wise when it is degenerated with a resistor.
Old 14th September 2012, 04:13 PM   #1158
Esperado's Avatar
Originally Posted by mikelm View Post
I have the feeling Christophe that you regard me as an audiophile that likes to see hifi as mythical art that lies outside the realm of the physical sciences - actually nothing could be further from the truth. ...
Oh, my goodness, not at all, and same for most of the SSA threads contributors, experienced and nice fellows.
We are not on the Blowtorsh thread :-)
It was just a general smiley/joke, never thougt at you in this manner, far from that.
Christophe.
Ultimate Protection
Old 16th September 2012, 06:40 PM   #1159
Idefixes's Avatar
Send a message via ICQ to Idefixes
Hi Esperado,
Here's the modification for feedback resistor feeding
Marc
website : http://audiyofield.wifeo.com/index.php
Old 16th September 2012, 06:58 PM   #1160
Lazy Cat's Avatar
To L. C., (Please comment ?) I'd like to see an improved SSA BIGBT HP's PSU for the following reasons:
I prefer a single power supply (when it is possible) for the both (or more) channels (as opposite to audiophiles) for the stereo localization (i explained it earlier).
If it is impossible, by example in my muti-ways active speakers, i prefer to use the same supply for all the channels (coherency of bass and treeble during big transients, same player shoot again).
For all those reason, i will prefer a PSU separated from the amp board.
Unless the rails are so perfectly regulated or stabilized, that you can forget about that, and enjoy the short wires low self.
Even here, i would prefer a single transformer, preferably a C core one with shield between the primaries and secondaries coils, to get no capacitive coupling between them , in order to minimize hf leakages between them.
I always use a ferrite on the power cord, (in fact on all the cords, including signal) and a HF rejection filter in the AC plug too.
Hi Christophe
All what you're telling us is so logical in explanations that I believe you, especially because I know you tested all these combinations practically on a real word circuits in familiar system.
I also had some amps, one very dear to me is still in my possession, named StereoLith. This has separate power supply formed by two toroids, one for the front-end another for the output, a lot of capacitance present, amps PCB-s having regulated rails for front-end, etc. But still it can not come even near to SSA BIGBT CCS's sound quality. Major responsibility for SQ lies in topology, parts, PCB layout and of course in PSU too. In SSA I follow the rule that everything is near to each other as possible, main caps to output BJT-s, etc. Also I like very compact PCB-s where's all onboard except toroid and I just did it that way. So far I have no complaints, it serves its purpose well, sounding well too, so mission accomplished successfully.
Regarding dual mono concept, I'm sure there's so little differences between channels that phase differences do not play significant role, also listening shows no worse stereo imaging than solid stereo amp, on contrary, to mine opinion it is even better.
Currently I'm preparing something even more compact than SSA, to be released soon, even before CSA BIGBT, you'll be surprised too hehe.
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
Page generated in 0.59910 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
