TSSA - The Simplest Symmetrical Amplifier - Page 114 - diyAudio
Old 13th September 2012, 09:39 AM   #1131
FdW is offline FdW  Netherlands
FdW's Avatar
Originally Posted by Joachim Gerhard View Post
I have the schematic.
Thanks Joachim it is different than the one I found.
Old 13th September 2012, 09:53 AM   #1132
Joachim Gerhard's Avatar
What do you think Frans : is R33 = 8 Ohm ?
Old 13th September 2012, 09:57 AM   #1133
FdW's Avatar
Yes, in both schema's, and that seems a bit(under statement) low (for the bias adjustment).
The mosfet in use http://pdf1.alldatasheet.com/datashe...HI/2SK135.html has gate protection build in, so why bother with external protection.
Also, I see (now) that the gate-source cutoff voltage at 100mA and Vds 10V is 0.15 to 1.45 Volt that may just be fine with the 8 Ohm bias regulator.
(I think this is edit 10 )
Old 13th September 2012, 10:20 AM   #1134
Lazy Cat's Avatar
Originally Posted by AndrewT View Post
Give as a link to the schematic/s.
Add that link and your descriptive comment to post1.
SSA BIGBT HP link.
Link also added to post #1 in SSA thread.
Old 13th September 2012, 02:58 PM   #1135
Banned
Originally Posted by Lazy Cat View Post
SSA BIGBT HP link.
L.C, On my computer, both links are broken: they point to a fake post number, then, goes to page 61, depending if you read the thread in reverse or normal order.
A working one ?
Simple Symetrical Amplifier
About thus adjustable resistance on my schematic, it is a value for sim.. I will have a look of the value of my adjustable in real world as soon i get some time and courage..
Old 13th September 2012, 03:50 PM   #1136
dadod is offline dadod  Croatia
dadod's Avatar
Christophe, i have checked your schematic.
Is R33, the bias resistor, really 8 Ohm ?
I wrote already about it. Look here Simple Symetrical Amplifier
dado
Old 13th September 2012, 03:57 PM   #1137
Banned
Original schematic of the Crescendo found here:
http://www.solaris.no/electronics/po...cresc_1280.gif
Value of the adjustable was 250 Ohms (unchanged -if i remember well- on my modified board.)
In the simul, value of the resistance was tuned for 150Ma of quiescent current in each Power mosfet.
Again, this mod was just for demonstration of CFB versus VFB.
I had tuned my board in real world in a first time, then closed the box with no notes.
Few weeks later, made and publish the simul as i was delighted by the improvement . Not sure the simul reflect the exact value of my real amp.
Unless you have yet a Crescendo at home, i will not recommand to build it, on many aspects, SSA BIGBT HP will be far superior.
As i said in the SSA thread there is no place, in the SSA BIGBT HP where i can feel like the slightest desire to change anything :-)
Driver is just top of the art.
And the Current Source is a pure perfection.
So, i understand why L.C. was upset reading "best T/SSA in the next few years is none of the circuits available today on this thread" ... after all this masterpiece work.
But L;C. is a cheater, using BIGBT, and we where discussing (in a general way) about using lateral Mosfets for power units, and i suppose Jay had not seen the HP version.
So, please, Jay, don't take the L.C. words too badly. You where not so wrong, after all, because SSA BIGBT HP was not in this TSSA thread :-)
The problem is those two separated huge threads, and the poor search tool of the forum.
Old 14th September 2012, 04:06 AM   #1138
Banned
...But the power supply.
Old 14th September 2012, 09:15 AM   #1139
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
We agree on that
Old 14th September 2012, 09:49 AM   #1140
. . . and I think my new supply will be a mix of chokes & cap multiplier
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
Copyright 1999-2017 diyAudio
