TSSA - The Simplest Symmetrical Amplifier
Old 13th September 2012, 12:10 AM   #1111
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Gate capacitors are really bad caps. Totally un linear, i agree on that. What about a buffer before them ? Have not seen that you in your Crescendo and also not in the TSSA.
Enough current is not enough. Low impedance drive would do it.
Old 13th September 2012, 12:57 AM   #1112
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Sonny's has emitter followers.
Old 13th September 2012, 01:01 AM   #1113
Sure, but that is a clever extension of the original circuit. BJT follower and LatMos current source ( drain out ) is the way to go. Simply raising the current drive without impedance transformation does not cut the mustard.
Old 13th September 2012, 02:56 AM   #1114
Jay is offline Jay  Indonesia
Banned
Originally Posted by Esperado View Post
So, i believe the only thing we can really do is to allow the driver to never run out of current in the worse situation with the gate resistance little enough for keeping the desired bandwidth in the worse situation too and forget about matching... Am-i wrong ?
That's what I have opted to believe.
The gate stopper, the source balancing resistor, the compensation capacitors (including intrinsic gate capacitance), all have similar effects to my ears, but with different severity, with capacitor being the worst (a lot worse).
I think one should not forget that the prime feature of the T/SSA is the possibility to use minimal compensation (for whatever target bandwidth). Even a cap as big as 47pF between base and emitter, like in Sonya's TSSA, is not my cup of tea. Cap across FB resistor is fine.
But of course, oscillation is not better than the existence of a small cap. But if we can get away with minimal capacitance, then thatís the way to go.
Capacitor between gate and drain/source to match the P and N imo is a strange decision. Gate capacitance is already the main issue with mosfet amps, now why add more? We can never match P to N anyway!
I have used this matching approach with Crescendo and Russel Bredenís amp, just to see if it improve anything, but I couldnít perceive improvement so I went with simple common sense.
Gate stopper has similar effect imo. We want as minimal as possible, but often, design dictates that a small amount is better than nothing. But 680R is too big imo. May be 470R is the maximum (otherwise change the design). The best value might be achieved from measurement or listening, but the difference wonít be too critical imo, so I have never wanted to waste time on finding the best value (mostly because I already have stock resistors for this purpose), nor to use different value between N and P channel gates.
Old 13th September 2012, 03:15 AM   #1115
sonnya is offline sonnya  Denmark
sonnya's Avatar
First of all.. The capacitance is placed between Collector and Base.
Second, they replaced an unlinear capacitor between drain and gate in the Renesas mosfet which KSC3503 and KSA1381 replaced....
If you say you don't want capacitors it plain rubish!!!!!!! You will proberly try to replace parts until it is stable. But then the parts you insert is with an unlinear capacitance...
Physics law give you capacitance every where you have to trace or metal surfaces with a given distance between them. The smaller this distance => larger capacitance. Larger surface area => larger capacitance..
Sorry, but you guys that want an amp without capacitors for compensation is completely of track....
I hope not that you are technicians or engineers!??? if so i think you have wasted time on your education...
Sorry for being that hard!
Old 13th September 2012, 04:15 AM   #1116
Banned
I believe that you do know the audible effect of the capacitors
But like I said, design issues usually dictate the use of the capacitor. It is then a challenge how to make the amp stable without too much capacitance. The CFB is already one solution towards that.
Of course, amp quality cannot be seen from the amount of capacitance or compensation. Only when the topology is similar, it starts to make sense to compare the amount of compensation used.
With the availability of computer aided design tools, designs should become easier, as long as designers know what they want to achieve. Simply throw away new devices into old circuits, and if we're lucky, we may get a wonderful amplifier. All amateurs can do this. Finding the sweet spot, that's what the pros should know better.
I would like to try low capacitance mosfet such as the ZVN/ZVP stuffs with that topology you use. May be you have tried (well, you should) but couldn't find results up to your standard. For me, building and comparing by ears is the last effort. Your decision with BJT and 47pF cap might be the best solution for the topology (at least for now), how can I know without building and comparing?
But anyway, I found that gate driving is the determinant factor for good sounding mosfet amps. And contrary to Joachim beliefs that we can get away with less with drain output amplifier, I found that drain output amplifiers also in the same trouble. Currently, the topology used by Nico and Shaan (SSA, Source output) is the best for LatFet for that matter. For drain output, try driving the gate with/from emitter of a TO-92 CFP.
I strongly believe that the best T/SSA in the next few years is none of the circuits available today on this thread
Old 13th September 2012, 07:12 AM   #1117
Esperado is offline Esperado  France
Banned
Is-it not the same thing ? Running out of current doesn't means to have too much impedance in the source ? I presume you mean cascodes in crescendo does not fulfill the requirement ? I 100% agree.
Not a bad idea to experiment on the major source of non linearity in an amp using power mosfets output devices. The driver stage has to be a near 0 Ohm output impedance for we can forget the C variation of the power gates and high speed. Not easy.
Means a more complex driver stage than a simple emitter follower, i think. A cascode emitter follower (we need bandwidth here) ? More gain with local feedback ? How much do we need to overkill ?
Old 13th September 2012, 08:07 AM   #1118
FdW is offline FdW  Netherlands
FdW's Avatar
IMO it is about a current source vs a voltage source, current sources (ideally) are high impedance and are not capable (mostly) to charge a capacitor in (near) 'zero' time (or there about). Voltage sources (ideally) have a 'zero' impedance, and thus are capable of charging capacitors in 'no time' at all.
Old 13th September 2012, 08:10 AM   #1119
Banned
Cascoded Darlington, if we can afford voltage drop ?
Originally Posted by FdW View Post
IMO it is about a current source vs a voltage source.
Of course, we were talking about voltage source with this "no current limitation".
Old 13th September 2012, 08:23 AM   #1120
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Listen very carefuly I will tell this only once.
The best SSA real world implementation so far is SSA BIGBT HP with CCS without any tiniest doubt. After VAS there's the most suitable source follower mosfet driver for the job, with lowest possible input/reverse capacitance influence, one can get on the market. Tested throughout and confirmed by listenting experiences.
Jay, before you write unconfirmed assumptions, it would be nice from you first to follow complete procedure: R&D, simulation, production, testing, listening, results. Standing still at sim results means nothing without practical realization of the circuit, it is like talking to the wind. So far you didn't show us anything more than just the letters on the screen.
TSSA - The Simplest Symmetrical AmplifierHide this!Advertise here!
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
Copyright ©1999-2017 diyAudio
