#1101 |
I think JLH argued in the original article that the 0.22 Ohm resistor somewhat helps to suppress back EMF entering the feedback chain. The lower impedance of the feedback resistors in a CFA could have a similar effect.
#1102 |
#1103 | |
dado |
#1104 | |
Transmission lines and 1/4 waves are probably the best enclosures for Bass, although not always possible (QTS of the boomer) and sooo complicated to build. :-) On my side, I do not care too much about the influence of the serial impedance of the amp on the response curve, as my speakers are all compensated (motional and self) to present a near flat impedance on all the bandwith (6ohms +- 1 ohms). So the influence of the damping factor of the amp is mainly on pulse response. Having a flat impedance helps the amp, too, because it do not have to deal with disparate (word is correct ?) Voltage/Current ratios, depending on frequencies. I will never understand why manufacturers do not care this aspect. |
#1105 |
diyAudio Chief Moderator
#1106 |
I don't know what kind of music you guys listen to, but for me Jazz is the most revealing, true "acid test", since PRAT (Pace Rhythm And Timing) is everything at Jazz. Live Jazz performances daily in summer time offers major experiences, sound absorptions, tasting and learning how live instruments and Jazz band should sound. System must be capable to reproduce near live experience and that happens only when PRAT is OK. Musicians come together playing the same tune, they're tuned together, if not, complex Jazz takes sounds like tune's falling apart, musicians not playing in the same composition. To me Y axis correlations (phase, time, frequency) are the most important ones, amplitude related distortions are much more tolerable.
![]() I could hear Jazz band from 1 km distance and I would immediately know it is live band playing: transients (speed), phase synergy, PRAT tells me that.
#1107 |
#1108 |
#1109 |
Salas, the later JLH with mosfet vas has transformed into a Fetzilla
![]() The idea of matching P and N channels (by differing the gate stopper resistance) are also still adopted in Fetzilla, not in your older version of JLH (I think mosfet was still new for him then). Even in Dadod version of JLH, JLH used a series of 2 resistors for gate stopper. In later model JLH used only one resistor, and that is lower value than yours (330R for N, 270R for P. Yours are 680R for both). Go figure
#1110 | |
Paralleling a cap to reduce the C delta, playing with gate stopper to equalize the low pass filter (created with the capacitance holes) between the P & N devices ? Never found a good enough response. So, i believe the only thing we can really do is to allow the driver to never run out of current in the worse situation with the gate resistance little enough for keeping the desired bandwidth in the worse situation too and forget about matching... Am-i wrong ? What are your experiences about this problem ? |
| simplest amplifier possible with BJT's? | rmgvs | Solid State | 123 | 10th July 2008 03:05 AM |
| Symmetrical Phono Amplifier | seroxatmad | Solid State | 3 | 6th August 2007 04:00 PM |
| Simplest class B Amplifier | PicancoNet | Solid State | 42 | 8th June 2005 02:55 PM |
| Symmetrical amplifier conundrum | Kilentra | Solid State | 22 | 31st January 2003 05:06 AM |
| Symmetrical 400W amplifier | Diogo | Solid State | 30 | 28th October 2002 11:00 AM |
