Old 16th April 2012, 09:18 AM   #101
Idefixes's Avatar
Send a message via ICQ to Idefixes
Originally Posted by Lazy Cat View Post
Mostly any 5 mm IR LED is okay.
At current If=3,5 mA, forward IR LED voltage is app. 1,2 V and that is too low for proper cascode, so please provide two of them in series on the PCB. That will provide Vce=1,8V for VAS BC transistor.
Ok i will do the modification.
Marc
website : http://audiyofield.wifeo.com/index.php
Old 16th April 2012, 09:18 AM   #102
MiiB is offline MiiB  Denmark
what is the benefit from the BIGBT...??
Old 16th April 2012, 09:40 AM   #103
Lazy Cat's Avatar
Hi MiiB
Mhmm I simply love this BIGBT
Easy to drive (low input gate capacitance) output transistor (yes I consider BIGBT as one joint part only), very stabile output transistor as integrity (balanced conditions for NPN/PNP), IRF conduct only one base current for both outputs, so for one base current (and it is the same for both outputs) through IRF driver you get two parallel collector curents for the output (doubled hFE). Linear transconductance dIout/dVg, high speed ... you should try it once.
Old 16th April 2012, 12:09 PM   #104
Lazy Cat's Avatar
Exclamation TSSA BIGBT HP update
Update released
Changes:
- VAS cascode - two IR LED per cascode
- "ON" RED LED added - indicates bias-on state
Regards Andrej
Old 16th April 2012, 02:22 PM   #105
terranigma's Avatar
Originally Posted by AndrewT View Post
the simplest !
post71 shows ~75 components.
I couldn't even count it.
Old 16th April 2012, 02:24 PM   #106
What happens when R6 and R7...are modulated with the input signal...??
Old 16th April 2012, 02:51 PM   #107
Lazy Cat's Avatar
R6, R7 are voltage dumpers to CCS, necessary to use because 2N j-fets have too low Vds/power dissipation specs. Current through R6, R7 is constant as CCS-s are capable of, so ideally no modulation should be present on these resistors. Of course it would be better to use source/sink transistors without voltage dumpers (double cascoded CCS). CCS are not ideal and there's always tendency to have increasing level of distortions according to higher frequencies. Separate measurements of CCS shows their capability to maintain the current to be constant. If you suggest to replace the resistors with improved CCS-s you are invited to do so.
Possible ripple suppression would be to add small parallel caps across R6, R7, just to prevent AC modulation (low level ripple) as voltage drop on them.
Old 16th April 2012, 02:54 PM   #108
Lazy Cat's Avatar
Question
Originally Posted by Bigun View Post
jeez, this is supposed to be the Simplest ? I think this thread has lost the plot along the way. Pitty, I like really simple.
Answer
Hi Bigun
I can not manage more than two threads simultaneously, so logically one would be full of stuff.
From simple to more complex version, all based on the same TSSA base core. It is the same like in school, gradually progressing the knowledge.
Regards Andrej
I hope you find it reasonable.
Old 16th April 2012, 03:52 PM   #109
what if you reverse the positions.. so you place the resistors at the rails and the current sources where they belong. then you get both....reduced dissipation and no signal induced current modulation.
Old 16th April 2012, 05:07 PM   #110
Think you should rearrange the driven VAS cascode... make the connection inside the Rail resistors for the input pair.
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
Copyright ©1999-2013 diyAudio
