#1061 |
diyAudio Chief Moderator
Intended speakers have a lowest 4 Ohm valley at power range 200hz-800Hz, but 95dB/1W, has the mojo for those?
#1062 |
Salas...
Install ALF16N16 and ALF16P16 and reduce RF and RG to 499R and 49.9R C12 and C13 should be 220pF. To for the lower gain as your speakers are very sensitive.... |
#1063 |
My speakers are sensitive but my preamp ain't, its a buffer...
#1064 |
But if your source can drive it to 2Vrms it should be ok. Else use 1K and 49.9R
#1065 |
Ask Joachim about powersupply as he has sensetive speakers too...
#1066 |
Phonographic source, low mc cart, not helping. I will use it as 26dB and see how it goes first. SSA 26dB Sziklai p2p A/B 175mA bias source follower proto was boom rocking them.
#1067 |
TSSA may do that too, lets let it speak first.
#1068 |
A cap multiplier was madatory on my build. Otherwise there was a small hum. I think that behavior is typical for class A amps with low open loop gain. See the JLH 10W.
#1069 |
Sounds like horn system!?
Boom rocking ? Negatively??? |
#1070 |
If it will do that I will multiply the snap-in F&T with a cheap slug then, TIP3055 maybe. So it will not oscillate or something. Yes?
| simplest amplifier possible with BJT's? | rmgvs | Solid State | 123 | 10th July 2008 03:05 AM |
| Symmetrical Phono Amplifier | seroxatmad | Solid State | 3 | 6th August 2007 04:00 PM |
| Simplest class B Amplifier | PicancoNet | Solid State | 42 | 8th June 2005 02:55 PM |
| Symmetrical amplifier conundrum | Kilentra | Solid State | 22 | 31st January 2003 05:06 AM |
| Symmetrical 400W amplifier | Diogo | Solid State | 30 | 28th October 2002 11:00 AM |
