TSSA - The Simplest Symmetrical Amplifier
Old 11th September 2012, 07:02 PM   #1051
padamiecki is offline padamiecki  Poland
Jay
your flag is upside down
regards, Pawel
Old 11th September 2012, 07:13 PM   #1052
smartx21 is offline smartx21  Brazil
Send a message via MSN to smartx21 TSSA - The Simplest Symmetrical Amplifier
Originally Posted by padamiecki View Post
Jay
They are inverted for Poland lies in the north hemisphere, contrary to Indonesia!
Max.
Old 11th September 2012, 07:52 PM   #1053
Esperado is offline Esperado  France
Banned
Originally Posted by Joachim Gerhard View Post
Christophe, would more open loop gain result not only in a higher damping factor but also less distortion ?
Well, when we increase the gain factor of 1 stage in an amplifier (with no other change) we often increase its own distortion. (= We reduce its local feedback) In a global loop, increasing feedback to compensate this adding gain will reduce back the global distortion. Did the result better or worse than before ? Hard to predict !
I think we can have a more accurate answer looking at the slewrate.
Old 11th September 2012, 08:25 PM   #1054
sonnya is offline sonnya  Denmark
sonnya's Avatar
I am not sure, is that 3V input or output ?
If it is 3V input then his simulation shows much lesser harmonic distortion as other versions of the TSSA i have seen.
Basicly the system closed loop gain is calculated with the following formula..
closed loop gain = A/(1+(A * Beta).
A is openloop gain.
Beta is the feedback network. For inverted configuration it is:
Beta = 1/(RF/RG)
For noninverted configuration it is:
Beta = 1/(1+(RF/RG)).
The TSSA as example. You will have a openloop gain A = 158.
Beta is 1/(1+(1K/100)) = 1/11 = .09091
Closedloop gain is: 158/(1+158*.09091) = 10.28.
In comparison with this one TSSA - The Simplest Symmetrical Amplifier who has a A = 1.000.000..
It is really bad with the TSSA. But it is helped along with CFP input pair wich have local feedback that lowers distortion from the input pair.
Also the mosfet runs in class A .. So the most of the time we do not need to struggle with crossover distortion.
The SSA maybe be better in terms gain. but it also have some unlinear parameters the TSSA does not have...
There is several parameters we can work with.
Reduce RF and RG to 499R and 49.9R => A = ~300
use double lateral mosfet => A = ~600.
Raise the resistor R8 and R7 to 2K => A= ~1200.
Whe have now reduced the distortion 8 times. And Zout is also lowered 8 times.
The system gain means that we 2VRMS to get maximum power. Most DACS and CD players can manage that.
Old 11th September 2012, 08:33 PM   #1055
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
R8 and R8 in what schematic ?
Old 11th September 2012, 08:36 PM   #1056
sonnya's Avatar
http://sitosite.dk/amps/TSSA-01300712.pdf
RF is R11 and R12 and RG is R13 and R14.
Old 11th September 2012, 08:44 PM   #1057
So lowering the feedback resistors raises the open loop gain. Is that the same mechanism as in CFB opamps ? Lowering too much would then cause instability.
Old 11th September 2012, 08:47 PM   #1058
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
May I use 1K/50R RF/RG for 26dB and still be kinda decent?
Old 11th September 2012, 08:54 PM   #1059
sonnya's Avatar
Joachim:
Exactly.... Except there no such thing as a stable amp with out Cdom capacitors in one form or another. In my amp it is C12 and C13.
Thats why i asked if the SSA design are stable into 10uF load (I think Quad electrostates are close). My designs are not stable without extentions in the design...
I really dont think the SSA are completly stable... Go for Megahertz they all say. Some of it is true... But you need take into account what you pick up of noise and how close you will come to instabillity..
They are now 47pF but i would suggest 220 - 330pF with all the changes above....
Old 11th September 2012, 08:55 PM   #1060
sonnya's Avatar
Yes of course, and you will preserve the Zout.
TSSA - The Simplest Symmetrical AmplifierHide this!Advertise here!
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
