TSSA - The Simplest Symmetrical Amplifier - Page 105 - diyAudio
Old 11th September 2012, 03:55 PM   #1041
Joachim Gerhard's Avatar
Chistophe, the discussion is not about the closed loop gain but about the open loop gain to be raised to get more leeway with feedback to lower distortion.
Old 11th September 2012, 04:10 PM   #1042
It ocurred to me that when we "turn around" the lateral Fets ( sources to output ) and ground the output as a transimpedance stage like padamiecki there could be a possibility to set Ugs to the right value and also get more open loop gain.
Old 11th September 2012, 04:57 PM   #1043
Jay is offline Jay  Indonesia
Please explain, I don't understand. Padamiecki used 3V input.
Old 11th September 2012, 04:59 PM   #1044
Banned
Ah, thanks, Joachim, sorry for my misunderstanding.
My thoughts:
I suppose the only interest is increasing open loop gain is with keeping the open loop bandwidth equal or better ? Is-it possible ?
As i said in the SSA thread, slew rate is the goal.
... Yes, more feedback gives a better damping factor.
... But, in an other side, it will produce higher signal in the feedback path and that can lead to more TIM ?
I suppose that optimizing this aspect will require a lot of listening test ?
Interesting question to explore.
Old 11th September 2012, 06:04 PM   #1045
Just in case anyone is wondering the question:
padamiecki, did you build that circuit or is it only in simulation ?
It has lower distortion then the TSSA circuits i have seen here.
Old 11th September 2012, 06:13 PM   #1046
I am not sure, is that 3V input or output ?
If it is 3V input then his simulation shows much lesser harmonic distortion as other versions of the TSSA i have seen.
Christophe, would more open loop gain result not only in a higher damping factor but also less distortion ?
Old 11th September 2012, 06:23 PM   #1047
input
regards, Pawel
Old 11th September 2012, 06:27 PM   #1048
Originally Posted by padamiecki View Post
input
with 10Vpp @input this topology became behave strange (-4Vdc offset)
but the wise men will do from this joke good follower
regards, Pawel
Old 11th September 2012, 06:32 PM   #1049
input
I'm more confused. I thought, of course Joachim knew for sure that it was input. And of course it has lower distortion. But how can I supposed to see it "apple-to-apple" with other TSSA distortions? I mean, there are many ways to make it even lower distortion, especially when it doesn't need to work as a normal amplifier...
Old 11th September 2012, 06:59 PM   #1050
anyway it is better than this
Ticle Zen Amp
(the last post)
regards, Pawel
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
Copyright 1999-2017 diyAudio
