TSSA - The Simplest Symmetrical Amplifier
Old 11th September 2012, 10:21 AM   #1031
sonnya is offline sonnya  Denmark
sonnya's Avatar
Old 11th September 2012, 10:31 AM   #1032
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Sonnya,
Didn't know if you would find this interesting. I just happen to be working on Nelson's F6, which uses transformer as phase splitter and came across this while looking around.
...Shape the sound , Man!
Old 11th September 2012, 11:09 AM   #1033
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Originally Posted by sonnya View Post
Excuse me for my lack of participation .... I have been rather busy, as i have been asked if i could design a preamp for hypex modules as hypex don't offer such a solution for there boards.
That's super and very honourable recognition from Hypex, good for them.
I can now tell my friends that I had opportunity to cooperate with Hypex designer.
OK, I'm very still in unrecognizable area but close, just bellow you somewhere.
Old 11th September 2012, 11:11 AM   #1034
sonnya's Avatar
no no no.... It is not hypex that have asked me!
Old 11th September 2012, 11:17 AM   #1035
Lazy Cat's Avatar
Oh I misunderstood, apologize Sonny
BTW did you have opportunity yet to listen to NC400 module? I only see praises all around the net.
Old 11th September 2012, 02:14 PM   #1036
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
padamiecki, did you build that circuit or is it only in simulation ?
It has lower distortion then the TSSA circuits i have seen here. I assume the 9mA current sources by pass the 4.7kOhm resistor. Otherwise the output will be totally over biased.
Old 11th September 2012, 02:21 PM   #1037
Esperado is offline Esperado  France
Banned
Originally Posted by Idefixes View Post
I understand andrew and apply what you suggest(see under). For your value proposal let LC answer...
Marc
Idefixes, the feed-back resistance's position are the worse you can imagine. You could improve a lot distortion by doing something like this:
Old 11th September 2012, 02:42 PM   #1038
sonnya's Avatar
The TSSA cannot run with 4.7K in its present state. But it is the way to go, to get more gain.
It is not precise enough in its currentsources...
Maybe version 1.7 will have this posebility.
Old 11th September 2012, 03:14 PM   #1039
Yes, that is the major problem of the TSSA, getting more gain without over biasing the output stage. padimiecki put in another twist, he grounded the output.
Old 11th September 2012, 03:39 PM   #1040
Banned
to get more gain.
What is the min V in we are supposed to get for full power?
775mV rms to fulfill DIN requirements ?
1V to match most of the digital equipment ?
1.25V to match professional symmetrical equipment ?
TSSA - The Simplest Symmetrical AmplifierHide this!Advertise here!
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
