Old 15th April 2012, 08:51 PM   #91
Lazy Cat's Avatar
Originally Posted by Idefixes View Post
Just a little precision : BJT Bigbt transistors are mounted under pcb "sandwiched" between pcb and heatsink surface by the screw.
Marc
Idefixes, you seriously grip the bull's saddle
Very nice PCB indeed.
Both IRF-s screaming to get in between the outputs, you see their tracks are way too looong.
Also the + and - outputs can be aligned with their pins.
Look down, sch update, just at the right time hehe
Old 15th April 2012, 08:54 PM   #92
Lazy Cat's Avatar
Exclamation TSSA BIGBT HP update
Here's an update with minor connection/parts changes, some values were recalculated.
Old 15th April 2012, 09:00 PM   #93
Idefixes's Avatar
Send a message via ICQ to Idefixes
I will take care all adwise. I tried with irf between BJT but not found solution in one layer...i will try again to integrate your advises.
Marc
website : http://audiyofield.wifeo.com/index.php
Old 15th April 2012, 11:09 PM   #94
Idefixes's Avatar
next.......
LC, what are this "IR LED". I would be nice if you could communicated me the resistors value change for -/+50Vdc....i am not able to calculate them...
Thanks Marc
Old 15th April 2012, 11:39 PM   #95
Bigun is offline Bigun  Canada
Bigun's Avatar
jeez, this is supposed to be the Simplest ? I think this thread has lost the plot along the way. Pitty, I like really simple.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 16th April 2012, 08:19 AM   #96
Lazy Cat's Avatar
Hi Bigun
I can not manage more than two threads simultaneously, so logically one would be full of stuff.
From simple to more complex version, all based on the same TSSA base core. It is the same like in school, gradually progressing the knowledge.
Regards Andrej
Old 16th April 2012, 08:31 AM   #97
Lazy Cat's Avatar
Exclamation TSSA BIGBT HP different supply voltages - resistor values
next.......
Thanks Marc
Hi Marc
Nice PCB improvement.
Attached schematic includes the table of calculated resistor values according to different supply voltages chosen.
IR LED is infrared light emitting diode, high performance one compared to average LED-s.
Old 16th April 2012, 08:32 AM   #98
Idefixes's Avatar
Hi Marc
Attached schematic includes the table of calculated resistor values according to different supply voltages choosen.
Youpi..that couldn't be better....I continue to work on pcb with some more components alignement and some mistake (0.22r 5W package) corrections.
On my version i put in the possibility to bypass the TLP627 since you have your own systeme to drive this unit -power management unit...if i remember-
Marc
Old 16th April 2012, 08:45 AM   #99
Idefixes's Avatar
Something like this : Product Folder - QED123 - Plastic Infrared Light Emitting Diode, Fairchild Semiconductor?
Marc
Old 16th April 2012, 09:14 AM   #100
Lazy Cat's Avatar
Mostly any 5 mm IR LED is okay.
At current If=3,5 mA, forward IR LED voltage is app. 1,2 V and that is too low for proper cascode, so please provide two of them in series on the PCB. That will provide Vce=1,8V for VAS BC transistor.
P.S. 2SA/2SC transistors needs on PCB 5-10°K/W heatsink, since they dissipate app. 0,7 W each at 75 V supply voltage.
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
Copyright ©1999-2013 diyAudio
