Building Elvee's Circlophone: Documentation, Parts, Accessories, & beginner friendly - Page 11 - diyAudio
Old 27th October 2012, 11:14 AM   #101
de Ocampo's Avatar
Hmm..
Old 27th October 2012, 11:27 AM   #102
danielwritesbac's Avatar
Originally Posted by abetir View Post
I'm using 2SC5200/A1943 for the output
With extraneously fast output devices, Click Here and install C11
I will edit post 1 and add this to the notes section. Thank you for the helpful questions that have been nice for improving the documentation.
You have mentioned "thump stopper accesory", do you also mean at turn on & off?
It is not because of the power amp. It is to reduce turn on and off thump from single rail sources. A normal Circlophone doesn't power thump, but a normal computer does. My computer is set for standby power saver and the computer outputs big thumps when it wakes up.
Can you please show it to me in the schematic..
Okay. Here is a piece of the proposed new input system. The added BAT86 are for reducing offset bounce (without needing the trimmer accessory). The added 3.3v zener and 39R are the thump stopper (for thumping sources). Zener are capacitive, about 0.8n when in series like that, and it also blocks RF as well as blocking HF noise from the source. The added parts are accessories that you may (or may not) like. The following attachment has experimental status.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 28th November 2012, 09:35 AM   #103
Here's Abetir's VAS heatsinks:
Nicely done! Thanks for the photo!
These heatsinks can be made with copper pipe.
Old 28th November 2012, 10:48 PM   #104
de Ocampo's Avatar
thanks!, they are actually heavy duty solder lugs with the flat top removed...
Old 29th November 2012, 12:17 AM   #105
I and several others need a briefing (directions) on how to make a PCB. Help?
Old 4th December 2012, 12:13 PM   #106
ItaPapu is offline ItaPapu  United States
Daniel, in your schematics Q5 and Q6 are reversed. It may not mean much, but it might create some confusion.
Old 6th December 2012, 02:21 AM   #107
You can find information on the subject on this site:
DIY Printed circuit board
There are many different ways of doing it, just chose your preferred one. Have fun.
Old 7th December 2012, 09:25 PM   #108
My apologies. Could you double-check the replacements (attached)?
Old 8th December 2012, 04:36 AM   #109
They are all good now. Thanks!
Old 17th December 2012, 11:47 PM   #110
Hello, I have 2 questions
Is the CFP version RF-immune?
Is it advisable to build on perfboard?
Building an AMP of a commecial piece but with top-notch parts Oystein Solid State 3 9th July 2009 10:22 AM
Beginner speaker building help Telemin Multi-Way 3 16th June 2009 12:23 AM
Beginner - Building a bass guitar cabinet richmoore1998 Multi-Way 3 27th December 2008 02:31 PM
Building a headphone amp from parts Smokehouse Bob Headphone Systems 13 13th August 2007 03:26 PM
speaker building (beginner) larksp Multi-Way 37 26th April 2007 03:41 PM
Copyright 1999-2017 diyAudio
