Values of +/- 24 volt Borbely PSU....
Old 1st October 2003, 09:37 AM   #1
jazzpeter65 is offline jazzpeter65  Denmark
Default Values of +/- 24 volt Borbely PSU....
I have just found this schematic for the Borbely EB-802/243 powersupply.
It's a wideband, lownoise powersupply designed for audio circuits.
Has anyone built thes unit? And can anyone tell me what the values of the components should be?
I only know, that r3=2.49K and R1=1K for the output to be +/- 24 Volts. Other outputs can be obtained by the formulae:
6.9x(R3+R1)/R1
The reference diodes is LM336Z-5.0.
Opamps could be NE5534.
Any help to get?
Best,
Peter
Old 1st October 2003, 06:59 PM   #2
Fred Dieckmann is offline Fred Dieckmann  United States
diyAudio Retiree
Default If you have to ask............
RTF*D
http://www.audiokits.com/downloads.asp
Or you could buy a kit from these folks or Borbely Audio I would imagine. Tell them Walt J. referred you. **
Just don't tell PA about it.
BTW There are this cool new things called search engines, but perhaps you might not have heard about them.
* That's Formal you suspicious moderators
** Sorry Jan the devil made me do it....
Old 1st October 2003, 11:56 PM   #3
Talking Borbely PSU...
Very funny....
www.audiokit.com is where I got the schematic from. They may have a reason not to put values on it...;-)
I have another Borbely PSU design I can use instead.
Look here - free to use high quality PSU:
Old 2nd October 2003, 11:49 AM   #4
carlmart is offline carlmart  Brazil
Both designs are based on Sulzer's supply, as far as I know.
The most modern version (Walt Jung's) is different because of the chips he used and because he added a feedback from the part you were powering. That is you should only use one supply for each chip you were powering.
From the photos I have seen, I think the small supply pcb Audiokits sells is based on Jung's design, but this is only a guess.
Carlos
Old 2nd October 2003, 02:33 PM   #5
pooge is offline pooge  United States
Default Get a better regulator
You are better off going to Andy's site and getting a reg from him. They are more advanced than Borbebly's, have high quality PCBs with plated through holes, and cost less.
I don't understand why Borbely uses a FET as a pass transistor, anyway. Walt Jung had the same question when I asked him about it.
ALW Audio
Old 2nd October 2003, 02:49 PM   #6
What's the URL of Andy's site?
The one you typed (AWL AUDIO) is a broken link....
Old 2nd October 2003, 10:17 PM   #7
runebivrin is offline runebivrin  Sweden
runebivrin's Avatar
Send a message via MSN to runebivrin
Must've been a temporary down time. Works OK now...
Rune
Do wizards use spell checkers?
Old 3rd October 2003, 12:59 AM   #8
diyAudio Retiree
Question We could tell you but we would have to kill you to keep it secret
"I don't understand why Borbely uses a FET as a pass transistor, anyway. Walt Jung had the same question when I asked him about it."
Erno knows...........
I know......
Andy knows.........
I bet even Walt now knows........
The open loop output impedance of the Mosfet is much higher than a bipolar at the same quiescent current which is a drawback rsulting in higher output impedance, but the Mosfet has the real advantage of ..........
I wonder who else knows?
Old 3rd October 2003, 01:19 AM   #9
diyAudio Retiree
Unhappy Re: Borbely PSU...
Originally posted by jazzpeter65
Very funny....
I'm sorry, the version I downloaded EB-802-243-complete.PDF awhile back had a parts list. Is that not the case now? Have you tried Emailing Mr. Borbely?
http://www.borbelyaudio.com/
Values of +/- 24 volt Borbely PSU....Hide this!Advertise here!
Borbely DAC board Prune Digital Source 22 17th September 2011 08:51 AM
Borbely ALL-FET DAC I/V stage hollowman Digital Source 34 6th December 2008 03:29 PM
FS Borbely Headphone Amp flocchini Swap Meet 0 19th September 2008 07:15 PM
Switching 230 Volt Transformer to 120 Volt OMNIFEX Parts 10 6th April 2008 04:34 PM
