Best VAS? - Page 21 - diyAudio
Old 14th August 2012, 07:15 PM   #201
dirkwright's Avatar
Originally Posted by tiefbassuebertr View Post
Check out my post #32 and #44
So, you're suggesting a cascode? do they have good PSRR? I have not tried that obviously.
Old 14th August 2012, 07:27 PM   #202
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Originally Posted by dirkwright View Post
Well, I got to thinking and fooling around. Two power transistors in SRPP formation. One watt into 8 ohms with about 1.5% distortion. Not terrible, but not outstanding either. Given that at the time there weren't any good complementary transistors, I guess this was not too shabby.
Let me suggest improvement:
1. Zener referenced to ground instead of + rail, and
2. Resistor between Zener and base of gyrator.
The Devil is not so terrible as his math model is!
Old 14th August 2012, 08:14 PM   #203
dirkwright's Avatar
Oh, I'm sorry, that is a CRD (CLD), not a Zener.
I wonder if an SRPP made from jfets (and thus self biased) would have better performance with changes in the power supply.
Otherwise, I'll just build the Leach amp.
Old 14th August 2012, 08:21 PM   #204
Wavebourn's Avatar
Ah, it is current source... I thought it was backward drawn Zener.
You may add one more transistor and feedback to it's emitter that will increase PSRR and decrease distortions and output resistance.
Back to the topic, I think the name "VAS" is misleading because in any real amp it is loaded on some impedance that is also non-linear. Even in order to amplify the "voltage" it has to be able to drive this impedance properly.
Old 14th August 2012, 08:28 PM   #205
forr is offline forr  France
forr's Avatar
With reference to your post #32,
I followed Hephaïstos-Perrot (Lavardin)'s works from the start of the beginning in "L'Audiophile" and then Peufeu's works, often mentionned on this forum, about thermal/memory distorsion.
I found the concept most interesting but the allegated facts were never undoublty demonstrated with standard NFB configurations.
So, last year, I did some real tests to check its existence.
You'll find them here (the text is in french, however there are tables of results which can be understand by anybody) :
Distorsions peu connues des étages d'entrée des amplis
My conclusion is that memory distorsion can't be said to be significative.
Currently, I'm finishing my third stereo Renardson MRJ7 which I am very fond of. Here is a description of the second MRJ7 I made (10 MBytes, in french again but with lot of pictures and a simple test of PSRR) :
L'amplificateur de Mike Renardson à transistors Mosfet | A comme Audio
Small box, small heatsink, small transfo, small caps (4400 µF), but no noise and hum, even when hearing headphones directly connected at the amp output. Because of its high loop gain, the MRJ7 has a high PSRR.
Old 14th August 2012, 08:46 PM   #206
dirkwright's Avatar
Can you show me please? I'm having trouble picturing your idea. For the attached circuit, the power supply has to be within +/-0.5 volt for good performance. It's like the VAS is balanced on a knife edge, which is not comfortable for me. (this is only for full power output, for much lower output the allowable variation in the power supply is at least twice that)
(T5 actually has it's collector connected to ground, not the -24V supply)
Old 15th August 2012, 06:55 AM   #207
tiefbassuebertr's Avatar
Great work and very good documentation - thank you. Unfortunately I don't speak french and thus I must try to convert the PDF text in MS-word about ABBYY FineReader for the possibility of the Google language tools use.
It would be interesting to know, what happens by connecting of a very large outdoor power supply to your MJR7 with the same voltage values behind the additional used chokes (low DC-impedance air coils like to see about
ZEN include active crossover without additional OP AMP for ultimate sounding PHL1230
arround 10mH/0,5 ohms).
I would use capacitor values of approximately 10mF until 20mF between rectifier and air coil and 20mF until 47mF between coil and amp, allocated close by the amp. I use for such projects 4 pcs or 6 pcs 12V lighting transformers (250-500VA each transformer - 1000VA - 3000VA at whole) that looks like this here:
http://img0.billiger.de/a/3269/267965158_L.jpg
My favorite caps for such applications are the follow:
http://www.mundorf.com/deutsch%201.1/kondensatoren2.htm
based on
http://www.ftcap.de/tl_files/ftcap/d...lyt/GW2012.pdf
The lighting transformers should be far away from the coils and the MJR7.
check also in this case my post #217 about
http://www.diyaudio.com/forums/solid...r-size-22.html
Old 6th January 2013, 05:46 AM   #208
chicks is offline chicks  United States
I just finished building an MJR7 MK5 myself. Had been sarching for a single-rail design that could use the 72vdc of the Dynaco SCA-80Q, which I found at a thrift store. The Dynaco's amp is primitive, but it's a nice chassis with a good power transformer, so the MJR7 was a great little DIY project. Really enjoyed Mike's no-nonsense design. He clearly knows his stuff. I've no doubt the amp performs as well as he claims, no way to measure, but my ears are happy.
Wish I read French, your analysis looks great.
Here's the board inside the Dynaco, with a heatsink salvaged from an old Sanyo receiver.
A superior VAS clamp and VAS current limit for the Blameless. GK Solid State 128 19th October 2011 03:03 PM
low VAS sealed better than high VAS? matos81 Subwoofers 3 7th April 2006 11:28 AM
Calculating VAS wolly Multi-Way 2 5th April 2006 02:20 PM
Help, Determining T/S VAS gjeff80 Multi-Way 10 1st February 2004 08:17 PM
Going way under VAS ralph-bway Multi-Way 1 28th January 2004 02:30 AM
Copyright ©1999-2017 diyAudio
