Power amps with very good control of the loudspeaker ! - diyAudio
Old 29th March 2012, 05:17 AM   #1
ashok's Avatar
Default Power amps with very good control of the loudspeaker !
Some amplifiers seem to have tremendous 'grip' on the loudspeakers. The bass sounds very 'tight' or whatever term one chooses to use. While low output impedance probably does help here, below a point it doesn't matter much as the speaker cable resistance dominates the scene.
I was wondering if certain circuit topologies enhance such behaviour ?
Which power amps clearly exhibit their ability to have very good control over the loudspeakers ? I'm sure the very large ones like Krell etc. fit the bill , but how about those that are in the 30 to 150 watt power range ? Is very high current capability a basic requirement for such performance ?
AM
Old 29th March 2012, 06:38 AM   #2
roender is offline roender  Romania
roender's Avatar
Current capabilities and low output Z, that's all you need :-)
Old 29th March 2012, 08:23 AM   #3
Jay is offline Jay  Indonesia
It means paralleled output devices and big trafos. I like big transformer and paralleled output even for low power amp (some 5-10W chip amps are capable of delivering above 3A peak current). EF is also better than CF. Push-pull over single-ended. Current feedback.
Old 29th March 2012, 08:37 AM   #4
roender's Avatar
I'm talking about tens of amps :-) ...
This high currents peaks can't be provided by transformer until is very big but can be easily delivered by high quality electrolytic capacitors with low esr and esl values placed in close proximity of output devices. PCB design is paramount ...
Old 29th March 2012, 01:09 PM   #5
ashok's Avatar
Right Jay on all counts. I wondered how many did think that current feedback mattered also . I think so too. My conclusions are just based on some observations and I haven't researched it !
And of course as Roender points out the supply capability is always required no matter what the circuit is. But is too much supply capacitance also a bad thing ?
And yes current paths make a huge difference.
However can someone come up with some models/names ? I think the Leak Delta 70 did very well in the LF department ( played through Wharfedale Dovedale 3's).
AM
Old 29th March 2012, 01:39 PM   #6
Hi Jay Not always is outright high current required, and I refer to Quad 303/ Quad ESL57, which more of a purpose design synergy of amp to speaker, where the 303 has very good control of the 57. The 303 is not brute current capable
Other noteworthys are the NAD 3020 as an example of a small amp.
and marantz 1060. Naim also put effort into the amp speaker relationship.. where they provided a speaker cable that matched their amplifiers.
So although current capability is a obvious solution, its not the only one, particularly when the speaker characteristic and measurements are known to make the amp part of the bigger picture.
Cheers / Chris
Old 29th March 2012, 02:16 PM   #7
asmith is offline asmith  United States
Try a pair of Levinson ML-2's driving Quad ELS 57's. Everyone talkes about Quad's not having deep base has never heard them driven with the right amps. The down side is about 900 watts in for 50 wats out per pair.
Old 29th March 2012, 08:36 PM   #8
tvrgeek is offline tvrgeek  United States
Oversimplified. That much I have learned. Are you talking about a single amp powering a multi-way system? A powered sub? What you may think is tight base is cleaner lower mids.
My 50W Rotel with a measured DF of 40 sounded cleaner on my Peerless XXL subs than several 200W amps with higher DF. On the other side, my HCA 1200 was hugely cleaner.
asmith,
Good amps help Quads, but I have heard then on ML's. Real bass, but not like I get from my Peerless 12's. Not even close. Remember back when ML actually sold quads? 2 in a stand painted black.
Old 29th March 2012, 08:54 PM   #9
KatieandDad's Avatar
Just avoid what I refer to as Oriental "Twing Twang" amps. Most British amps have a good control over the speakers. I've got a Pass Aleph 4 which is an American design that also controls the speakers well.
Rotels are excellent, earlier Technics (which are becoming rare) and of course any of the audiophiller amps are also very good. Best thing is to borrow an example of each one and see what you like. The early Denon PMA7XX series were also very good and can be bought at a good price.
Lately the Oriental manufacturers have been bowing down to cheaper mass produced Class A/B designs which are not as good.
IMHO Class A is the way to go.
B&W, the highly reputable British speaker company use Rotel amps, or at least they used to.
Old 29th March 2012, 08:57 PM   #10
Boscoe is offline Boscoe  United Kingdom
Using a passive crossover? Throw it in the bin and amps and speakers all of sudden sound out of this world!
I CANNOT STRESS HOW BAD PASSIVE IS!!!
I thought about it once, but then thought again.
incorporating tone control ckt on power amps nfb audiomachines Solid State 0 11th February 2009 11:49 AM
Gross loudspeaker cone movement when using tube amps. colinB Tubes / Valves 41 10th July 2007 11:19 PM
How to build a truly good conventional box loudspeaker? keyser Multi-Way 8 30th August 2006 04:03 AM
Why do some Bogan amps sound so good as guitar amps? amperex Instruments and Amps 7 22nd June 2006 12:46 PM
Active Loudspeaker Amps - BMM sdclc126 Multi-Way 0 27th January 2005 10:00 PM
Copyright 1999-2017 diyAudio
