Final output stage amp marshall - Page 2 - diyAudio
Old 3rd April 2012, 03:02 PM   #11
Originally Posted by epicyclic View Post
It seems like you have marginal stability problems .
Check C13 ...220pf.....this helps keep the power amp stable
Check all the feedback components/wiring around IC1B .
I replaced all components, including the IC.. I checked all circuit comparing with the diagram... And I connected the preamp to the power amp with a microphone wire... I also tested the preamp with separate power supply, same problem ..
Old 3rd April 2012, 06:35 PM   #12
I was looking for another diagram, and I found this photos from a Marshall 3005 Lead 12 SS:
I have noticed many differences between these pictures and the diagram, for example, R2 is 2k2 on amp of the photos, but the diagram it is 33k .. And on the photo, the amp have a bias adjustment, the diagram don't...
Look to the attachment .. I'm seeing right?
Best and final TDA1541A output stage studiostevus Digital Line Level 14 14th March 2013 04:42 AM
Completely differential amplifier final stage exeric Tubes / Valves 14 28th April 2010 06:21 PM
The CMP Final Stage Stee Solid State 0 23rd December 2008 05:49 AM
Final Stage of Building UcD400 ruangrit Class D 3 29th November 2005 01:01 AM
increase the bias current of an opamp final stage herve Solid State 19 15th September 2003 12:29 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
