Has anyone seen this front-end before?
Old 4th December 2012, 05:03 AM   #1051
wahab is offline wahab  Algeria
Originally Posted by Bonsai View Post
Why don't you just buffer it and be done with it?
See the curves above , the buffer should have less than 1pF and more
than 50 Mohm input capacitance and resistive input impedance respectively ,
so micro meter node fets are required as it s not feasible with discrete components.
For the same reason, an eventual miller compensation must be buffered from
VAS output to its input , using a fet as well.
Old 25th January 2013, 05:24 AM   #1052
keantoken is offline keantoken  United States
keantoken's Avatar
I was considering building the STIS+AB2 amp as a prototype but I can't get it fully stable in simulation. I always end up with C24/C25 having to be 10nF or so for marginal stability, and this makes distortion abysmal.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 25th January 2013, 06:03 AM   #1053
keantoken's Avatar
I mean C17 and C18 in my schematic. C24/25 in Figure 12 here:
Super TIS
Old 25th January 2013, 09:08 AM   #1054
Edmond Stuart is offline Edmond Stuart  Netherlands
Edmond Stuart's Avatar
Hi Keane,
A few components are in the wrong position. C17 & C18 should be connected to the emitter of Q13 resp. Q14 and R17 (left side) should be connected to the node R9-R14. Perhaps there are more errors (I didn't check the whole schematic).
Success!
E.
Een volk dat voor tirannen zwicht, zal meer dan lijf en
goed verliezen dan dooft het lichtů(H.M. van Randwijk)
Old 26th January 2013, 01:45 AM   #1055
keantoken's Avatar
Thanks Ed. Now it makes sense!
I was wondering about the input filter. This amp must be intended to have a low-impedance source. Audio impedances at the feedback and input nodes are roughly equal, which makes sense. C2 is what I don't understand (your schematic). It is not large enough to bootstrap the input capacitance, which is still somewhere near 2-3nF. I understand the purpose of this arrangement is to achieve a 2nd-order BW limiter, but what does C2 do?
Old 27th January 2013, 02:36 PM   #1056
>... a 2nd-order BW limiter, but what does C2 do?
It changes it into a Sallen-Key filter.
E.
Old 27th January 2013, 04:44 PM   #1057
keantoken's Avatar
I read as much earlier in the thread, but I can't figure out why that would be useful. It appears to increase the Q of the LP corner by applying positive feedback. Does the extra BW justify reducing the effectiveness of the LP filter?
Old 28th January 2013, 06:24 PM   #1058
Because most people like a clean step response, i.e. critically damped.
E.
Old 28th January 2013, 09:55 PM   #1059
keantoken's Avatar
I think phase linearity should be the measure of "cleanliness" of AC/step response. AC response can be flat but have an anomalous step response because of phase nonlinearity. Group delay can be plotted in LTSpice using the Tg() function. The value of 22pF for C2 hardly affects response. Here are my simulated curves with and without C2 (C6 in my schematic).
Old 28th January 2013, 10:28 PM   #1060
If C2 hardly 'affects' the response then it should be recalculated.
BTW, in my latest design (by now 6 month old) I've deleted C2, probably for the same reason.
If this answer sounds a bit lame, I'm sorry. Reason: I'm still very busy with DiAna.
E.
Has anyone seen this front-end before?Hide this!Advertise here!
Bogen Front End lpd Tubes / Valves 2 5th March 2008 04:12 AM
NE5534 with a new front end ...anybody? ashok Solid State 9 2nd June 2006 01:30 AM
My New Front End Pics! micb Car Audio 1 26th May 2006 02:26 PM
Noisily front end mantistube Analogue Source 10 16th January 2006 01:57 AM
Front end for sub amp mashaffer Solid State 9 22nd July 2005 03:35 AM
Copyright ©1999-2017 diyAudio
