Has anyone seen this front-end before?
Old 20th September 2012, 12:49 PM   #1011
Dave Zan is offline Dave Zan  Australia
Originally Posted by HarryDymond View Post
Sadly many high-voltage, high-Ft, ultra-low capacitance BJTs have been discontinued by their respective manufacturers...
I don't like ON's drivers. I don't understand why, when they can make the excellent 3281/1302 etc. output transistors, they don't also make something more like the 2SC5171/2SA1930 from Toshiba as drivers. Alarmingly, these Toshiba parts have become NRND (Not Recommended For New Designs), which in turn will become "obsolete" soon. Apparently they are working on replacements though, so fingers crossed! (the 2SA1837/2SC4793 are also NRND).
Like the Toshiba but without the pathetic SOA when you crank up the volts.
I know there is a trade-off but I think you are correct, the overall performance of the 4281/4302 is excellent why not a comparable driver?
What is the story on the Toshiba replacements?
I stocked up on 4281/4302 when they were discontinued, should I stock up on drivers - is there a better option than 2SC5171/2SA1930?
And thanks for the ASC a day or so back.
Have not had a chance to do much yet.
Best wishes
David.
Old 20th September 2012, 01:29 PM   #1012
HarryDymond is offline HarryDymond  United Kingdom
Yes, the SOA is a bit of an issue on those parts. Still, the capacitance is so low that using two in parallel shouldn't slow things down much.
All I know is that if you look at Toshiba's latest BJT catalogue, it lists some transistors with suitable ratings (160V/1.5A and 230V/1A) in TO126 packages as "being planned".
The Fairchild KSA1220A/KSC2690A have similar performance. The SOA is better, but both parts have slightly lower Ft and the NPN part doesn't have a flat beta vs. Ic characteristic. Both Fairchild and Toshiba parts are available from Mouser at reasonable prices.
You're welcome.
Old 20th September 2012, 03:26 PM   #1013
Here's another output stage with op-amp-based drivers. Anyone seen anything like this done before?
Old 20th September 2012, 11:42 PM   #1014
Default Drivers
... if you look at Toshiba's latest BJT catalogue, it lists some transistors with suitable ratings (160V/1.5A and 230V/1A) in TO126 packages as "being planned".
The recommended "replacements" have lower maximum current and lower Vceo in a smaller format so presumably even worse SOA. Maybe time to stock up a little.
Thanks for the heads up.
Best wishes
David
Old 21st September 2012, 06:44 PM   #1015
keantoken is offline keantoken  United States
keantoken's Avatar
Harry:
The floating supply ground ill have significant capacitance to ground from the amp output no? This ill need to be considered for stability reasons. Furthermore the large surface area of the transformer and hatnot could radiate statically quite a bit.
The MJE253/243 are comparable to or better than the C4793/A1837. Furthermore, if e just get a bit more comfortable ith paralleling drivers, e ill preserve Ft ithout sacrificing it for higher poer. This is based on the datasheets and Cordell's SPICE models.
Cbe is VERY important! It basically determines the speed limit for practical usage of any given BJT. There are some seemingly nice lo-Ccb BJT's that have monstrous Cbe and therefore are useless. Cbe is hat caused the slo-rising slope of Ft ith Ic. It is also hy the KSC1220/C2690A are not very useful at 10mA. BJT's ith less Cbe generally increase the stability margins, and therefore useful bandidth, of any amplifier they are used in.
Cbc can be cascoded out or compensated for, but there is usually no ay to fix the inherent speed limit caused by Cbe. If the driver stage of a BJT EF amp is made poerful enough to deal ith Cbc, Cbe then becomes the limit on the stage's bandidth. It can be increased slightly by hanging capacitors about 5xCbe off of the output, hich allo quicker charge/discharge through Cbe. But only slightly, and it results in a steeper negative bandidth slope. Furthermore the Cbe of output BJT's is usually monstrous, hich results in 15-20nF necessary, and this makes stability in a global feedback design problematic. So basically - use the outputs ith the least Cbe, hich are at the moment the ONSemi outputs (they are not all the same). Look for Ft at 100mA, try to go above 20MHz. I prefer my small signal transistors to have at least 100MHz at 1mA.
I think the reason the TIS has such lo distortion itself is because it is basically the most linear a BJT input stage of it's type can be. Therefore, even if input-feedback differential is significantly large, it is still a largely undistorted reproduction of the output currents - IE high open-loop linearity.
hat gets me is that no one is trying to reduce the voltage distortion of the output stage; e can and already have increased input impedance beyond insignificance but the voltage distortion is still as large as it alays as back to the original double EF.
Dadod:
Instead of 10k resistors to the rails, feed the diamond pair ith resistors across the Vbe of Q3 and Q4. This ill increase the input impedance greatly.
Furthermore, you can cascode the BC5xx pair by putting a diode beteen the CCS and the driver emitters, and connecting the BC5xx collectors beteen the CCS and diode. After this both your input resistance and capacitance ill be greatly reduced. To diodes may be better, but may not because the BC5xx series has such great lo-Vce handling ability (but the BC327-25/BC337-25 are still better in this area).
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 21st September 2012, 08:29 PM   #1016
dadod is offline dadod  Croatia
dadod's Avatar
Originally Posted by keantoken View Post
Dadod:
Do you mean like this? Still the same input resistance and a nasty peak at 20 MHz, distortion a bit higher.
dado
Old 21st September 2012, 08:32 PM   #1017
Kean,
have you tried alt+0119? = w. alt+087 = W
More hassle for you, but would make the posts readable in the short term !
regards Andrew T.
Old 21st September 2012, 09:04 PM   #1018
keantoken's Avatar
Dadod:
If those are ideal diode models, check they actually have .68V breakover.
The resonance peaks kind of go ith multi-cascode output stages, because cascoding adds positive feedback paths. For one thing, those bulky MJE1503x drivers are super-overpoered. They ill never sink more than 100mA, and never see a Vce over .6V. Problem: overpoered BJT's have bad lo-Vce behavior. In this position these drivers ill have huge parasitic capacitance and possible Vcesat glitches.
Find some higher-performance drivers. The 2SC4793/A1837 ould be great, so ould the MJE253/243. They ill only dissipate 200m, so you could perhaps even use some TO92's here, as long as they are fast and linear to 100mA.
After you have better drivers, see hat the resonance is like and e can probably do something about it.
The distortion ill alays be bad because you are measuring voltage distortion. There is not much you can do about that ithout using a different circuit. A more meaningful measure of distortion for your circuit ould be input current distortion.
Andre:
Not sure hat you mean about the alt numbers. Ho do you do this?
The BJT tests ere only to help me get a sense of scale; I agree they're not very useful. They performed their function ell didn't they?
Old 21st September 2012, 09:38 PM   #1019
dadod's Avatar
Kean, if you like to play with this OPS here is LTspice file. I used MURS120 diodes and the MJE253/243 in this simulation.
dado
Old 21st September 2012, 09:41 PM   #1020
Krisfr is offline Krisfr  United States
Krisfr's Avatar
Kean hold down the ALT key and then strike 119 only on the Numeric Keyboard not across the top of the letters.
Never give a Systems Analyst a screwdriver or hammer
Has anyone seen this front-end before?Hide this!Advertise here!
Bogen Front End lpd Tubes / Valves 2 5th March 2008 04:12 AM
NE5534 with a new front end ...anybody? ashok Solid State 9 2nd June 2006 01:30 AM
My New Front End Pics! micb Car Audio 1 26th May 2006 02:26 PM
Noisily front end mantistube Analogue Source 10 16th January 2006 01:57 AM
Front end for sub amp mashaffer Solid State 9 22nd July 2005 03:35 AM
Copyright ©1999-2017 diyAudio
