#661 |
No, sorry it was not clear. What I meant was that the 0 dB line should be -180 phase (= 0 PM). Not 200 phase as in this plot. In the previous post it varies between plots. In the middle it's -200 but the others are -240. Inconsistency makes comparisons harder.
A consistent use of 0 dB = 0 PM would make it instantly obvious if an amp was stable Best wishes David. |
#662 |
It is obvious as well as the phase absolute value is aligned with 0dB gain......
#663 |
When the plot windows is focused, press CTRL+A and type "1" into Expression field, without quotation marks.
#664 |
To all LT spice user:
In order to enhance the readability, also change the background color of the graphs from black to white and regarding schematics from grey also to white and without grid. Thank you. Cheers, E.
Een volk dat voor tirannen zwicht, zal meer dan lijf en goed verliezen dan dooft het licht…(H.M. van Randwijk) |
#665 | |
dado |
#666 |
To me the schematic looks much better, the graph however, is too much cluttered with grid lines. Is it possible to reduce the number of vertical grid lines?
Cheers, E. edit: I don't like books either printed on grey or black paper.
Een volk dat voor tirannen zwicht, zal meer dan lijf en goed verliezen dan dooft het licht…(H.M. van Randwijk) Last edited by Edmond Stuart; 10th July 2012 at 11:50 AM. |
#667 |
Now?
I dn't know how to reduce the number of vertical grid lines. |
#668 |
I don't know either. Nevertheless it looks better now.
Thanks.
#669 |
Hello Edmond,
Check - Y G M Cheers |
#670 |
| Bogen Front End | lpd | Tubes / Valves | 2 | 5th March 2008 04:12 AM |
| NE5534 with a new front end ...anybody? | ashok | Solid State | 9 | 2nd June 2006 01:30 AM |
| My New Front End Pics! | micb | Car Audio | 1 | 26th May 2006 02:26 PM |
| Noisily front end | mantistube | Analogue Source | 10 | 16th January 2006 01:57 AM |
| Front end for sub amp | mashaffer | Solid State | 9 | 22nd July 2005 03:35 AM |
