Has anyone seen this front-end before? - Page 60 - diyAudio
Old 3rd July 2012, 07:51 PM   #591
Steven is offline Steven  Netherlands
Steven's Avatar
Originally Posted by Edmond Stuart View Post
>Are you going to use relay speaker protection on the output.
Yes, by means of a relay or low Rdson MOSFETs. Don't know yet which of the two.
E.
Chocoholic once posted a circuit for a MOSFET relay:
http://www.diyaudio.com/forums/solid...ml#post1997422
Distortion seemed to be virtually unmeasurable in practice.
Steven
The Analog Art shows no sign of yielding to the Dodo's fate. The emergence and maturation of monolithic processing finesse has perhaps lagged a bit behind the growth of the Binary Business. But whereas digital precision is forever bounded by bits, there is no limit excepting Universal Hiss to the ultimate accuracy and functional variety of simple analog circuits. - Barry Gilbert, 1973
Old 3rd July 2012, 07:58 PM   #592
Smiley 09's Avatar
Hello Edmond,
Y G M
Cheers
Old 3rd July 2012, 09:30 PM   #593
Thanks Damir.
I will have a look at it later on, because at the moment I'm finishing the adaption* of the schematic to the PCB version (a lot of work). Besides, LS protection will be put on a separate PCB and will be one of the next steps.
* That also means the incorporation of a DC servo, making the amp even more complex. As a matter of fact, I'm doing it with huge aversion: adding (read: wasting) needlessly a dozen extra components, simply because some gurus say that any electrolytic cap (no matter what type or brand) in the NFB loop is bad.
E.
Hi Edmond,
I plead guilty. I like DC servos and hate electrolytics in the signal path. A decent DC sero takes only a few components and often less board space than a good electrolytic. BUT, I will admit that, as I pointed out in my book, that a non-polar electrolytic of generous voltage rating, like those used in a loudspeaker crossover, can perform (at least measure) extremely well.
Bob
Old 3rd July 2012, 09:40 PM   #594
Edmond, doesn't the PGP have an electrolytic in the feedback path? Doesn't the PGP get at least -120 dB distortion across the audio band at all output powers from 1 watt to 100 watts into 8 ohms? What exactly then is the problem?
Old 3rd July 2012, 09:48 PM   #595
wahab is offline wahab  Algeria
Bob
A 220uF to 1mF capacitor is that huge.?...
Old 3rd July 2012, 10:31 PM   #596
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
Caps are not that bad. . . ;-)
I think this is more of a personal choice thing since the AP shows no distortion.
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Old 4th July 2012, 12:06 AM   #597
Bonsai's Avatar
Steven
You can also use non isolated drive on the mosfets as well. If you switch the speaker ground return line, the drive is very simple: Audio Amplifier Design and Circuits | hifisonix.com a topics down from the top of the page.
bonsai
Old 4th July 2012, 01:19 AM   #598
I said a GOOD electrolytic :-).
Bob
Old 4th July 2012, 08:18 AM   #599
Edmond Stuart's Avatar
Hi Edmond,
You could keep the elcap in the servo, but still isolate the servo almost completely from the amplifier, just using thermal coupling between servo an amplifier. Tandberg did that with some of their amplifiers in the past. Example: Tandberg 3000A, shown here. Q102 is the servo LTP driving two resistors R111 and R110, thermally coupled to the diodes CR101...104 of the input bias current sources.
I assume most audiophiles will not argue a servo with no electrical connections to sensitive input circuits. Also, the loading of the amplifier output with an RC filter to drive the servo will not harm any half decent amplifier.
Furthermore it is an open loop amplifier (i.e. no global feedback) with Hawksford EC for the power stage with MOSFETs.
Attachment 290036
Cheers, Steven
Hi Steven,
Thanks for providing the schematic. Indeed, a thermally isolated servo is a very clever and original solution. I've never seen this before.
BUT.... it has the same drawback as a conventional servo: over twenty additional components. It is again a trade-off between complexity and performance; that's precisely my dilemma.
BTW, maybe using optocouplers for isolation also provide a viable solution.
Thx for the hint!
E.
Een volk dat voor tirannen zwicht, zal meer dan lijf en
goed verliezen dan dooft het licht…(H.M. van Randwijk)
Old 4th July 2012, 09:40 AM   #600
Default dilemma
Hi Harry,
The problem is that other people make a problem of it.
E.
Hi Edmond,
Hi Bob,
I'm afraid I have to disagree with your definition of a 'few'. The DC servo on page 165 of your book consists of 10 components. Add to this number 12 components for a stabilized +/- 15V PSU. So in total, 22 extra components.
As for board space, in the PGP amp a Panasonic bipolar cap was used, 470uF, 16V, diameter: 16mm, protected by two DO-35 diodes.
Bob
My aim is trying to build an amp that can withstand any kind of critic. So if I'm using an electrolytic cap in the signal path, even in case of a proven distortionless one, there will always be people who have serious objections to its use.
Now the question is: should I raise a middle finger to those people*, or should I give in to their objections and add (read: waste) 22 extra components? I would be much obliged if you help me to overcome this dilemma.
* people who also advocate using polystyrene caps for decoupling the supply rails.
E.
Bogen Front End lpd Tubes / Valves 2 5th March 2008 04:12 AM
NE5534 with a new front end ...anybody? ashok Solid State 9 2nd June 2006 01:30 AM
My New Front End Pics! micb Car Audio 1 26th May 2006 02:26 PM
Noisily front end mantistube Analogue Source 10 16th January 2006 01:57 AM
Front end for sub amp mashaffer Solid State 9 22nd July 2005 03:35 AM
Copyright ©1999-2017 diyAudio
