Has anyone seen this front-end before? - Page 57 - diyAudio
Old 30th June 2012, 02:20 PM   #561
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
Quote ". . . , for (the sake of ) the pope s balls...."
LoL! :-)
bonsai
https://www.ovationhifidelity.com/ and DIY here http://hifisonix.com/
Old 30th June 2012, 02:30 PM   #562
Originally Posted by Edmond Stuart View Post
In addition, I've changed the frequency compensation of the OPS to a 2nd order
The loop around the OPS (Fig 12c) showed conditional stability. You have moved to second order to improve the stability?
Also curious about Fig 7. Why the low frequency roll-off?
And a last one for today - in Fig. 12 C22 and C23 could be combined and tied to point OPSIP in a natural way. Any reason to use 2 capacitors?
Best wishes.
David
BTW in Dutch we say: 'voor de kat z'n kut' In polite conversation?
Old 1st July 2012, 04:20 PM   #563
Edmond Stuart's Avatar
Default compensation details
At the same time time I've increased the time-constants of the OPS compensation somewhat. As a result, the PM is about the same, while the distortion is decreased by ca. 40%. Notice that this kind of compensation differs from Miller or TMC. Should we call it 'feed-forward compensation' (comparable to the compensation in Bob's HEC-OPS)?
RC5 and CC5 define the second order response, but at the same time CC5 also provides some phase lead.
What you see there is the local loop gain of the Miller compensation (the lower the frequency, the higher the impedance of the Miller caps, the lower the loop gain, hence...).
The intention here is that the Miller caps (C19 & C20, see pic below) are directly connected to the output of the TIS buffers, i.e. to the emitters of Q21 respectively Q22. Tying them somewhere in the middle of the OPS compensation network is not a good idea.
Best wishes.
David
(literally: 'for the cat his cυnt')
In the presence of our queen, I wouldn't use those words.
Een volk dat voor tirannen zwicht, zal meer dan lijf en
goed verliezen dan dooft het licht…(H.M. van Randwijk)
Old 1st July 2012, 07:17 PM   #564
To all,
BTW, does anybody know where to buy reasonably priced low inductive 5W SMT resistors between 0.2 and 0.3 ohm (preferable 0.22 ohm)?
E.
Old 1st July 2012, 07:28 PM   #565
nl.mouser.com? Just looked and they have a reasonable selection in your stated power and resistance range. I guess it depends what you mean by "reasonably priced"; I find these low-ohm power SMT resistors to be surprisingly expensive (i.e. I spend more on Re resistors than I do on output transistors!)
Old 1st July 2012, 07:33 PM   #566
That's exactly the trouble.
Old 1st July 2012, 08:00 PM   #567
wahab is offline wahab  Algeria
That makes Renesas laterals quite more competitive since you can
parralel them straight on , without any source resistors..
Old 1st July 2012, 08:15 PM   #568
But I also need them as current sense resistors.
Last edited by Edmond Stuart; 1st July 2012 at 08:26 PM. Reason: resistor -> resistorS
Old 1st July 2012, 08:27 PM   #569
That was to be expected...
Never mind , laterals are friendly devices , the current is in proportion of Vgd ,
wich vary at a 1V/A/Device rate or so (Gm = 1S) , just take the sensing point before the gate resistor.
Old 1st July 2012, 08:48 PM   #570
PHEONIX is offline PHEONIX  Australia
To all,
E.
Hello Edmond,
Are you going to use metal oxide types.
Arthur
Bogen Front End lpd Tubes / Valves 2 5th March 2008 04:12 AM
NE5534 with a new front end ...anybody? ashok Solid State 9 2nd June 2006 01:30 AM
My New Front End Pics! micb Car Audio 1 26th May 2006 02:26 PM
Noisily front end mantistube Analogue Source 10 16th January 2006 01:57 AM
Front end for sub amp mashaffer Solid State 9 22nd July 2005 03:35 AM
Copyright ©1999-2017 diyAudio
