Has anyone seen this front-end before? - Page 21 - diyAudio
Old 9th May 2012, 09:04 AM   #201
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
Edmond, interesting comments about the bipolar vs JFET input! Very difficult now to get matched JFETS, so I guess the fact that they are unobtainium just drives up their street cred . . . but I doubt there is anything magical about them.
That said, for single ended designs they are ok, but a degenerated bip is just as good if not better other than the noise from the degen resistors, but thi sis not an issue on a power amplifer IMO.
Anyway, I really enjoy reading your stuff - very nice - please keep it coming.
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Old 9th May 2012, 12:13 PM   #202
Edmond Stuart's Avatar
Hi Andrew,
Thank you for your encouraging words.
I did just that. See fig.17: SuperTIS + Bod Cordell's HEC output stage.
E.
PS >but a degenerated bip is just as good if not better other than the noise from the degen resistors,
They are just 10 Ohms. So, not much to worry about the added noise.
Een volk dat voor tirannen zwicht, zal meer dan lijf en
goed verliezen dan dooft het licht…(H.M. van Randwijk)
Old 9th May 2012, 03:31 PM   #203
Default More on RFI
The previous RFI sims made me suspicious. Therefore I've repeated the sims with a smaller HF signal: 100mV instead of 1V.
Code:
Front-end:               SuperTIS-BJT   SuperTIS-JFET   HEC-BJT    HEC-JFET
Demodulated AM signal:      5.4uV          1.26mV       0.35mV      0.82mV
THD20k without HF carrier:  0.028ppm       0.071ppm     0.19ppm     0.76ppm*
THD20k with HF carrier:     0.030ppm       0.072ppm     0.24ppm     26.3ppm
THD20k increase:            0.002ppm       0.001ppm     0.05ppm     25.5ppm
Now the differences between AM detection levels and compression distortion are far less extreme.
See also my website.
E.
Old 10th May 2012, 10:18 AM   #204
Default high Z & phase margin
Originally Posted by jcx View Post
- I expect best performance would had with error corrected/local feedback output stage giving high input Z, gain close to 1
Hi JCX,
Your absolutely right. As a matter of fact, it needs a very high input Z. Driving for example Bob's HEC-OPS directly (i.e using Bob's Q20 & Q21 as pre-driver ), yields less favorable results. But... using a separate pre-driver, configured as diamond buffer with bootstrapped collectors, works nice: THD20k = 3.1ppm (without TMC). See fig.17.
will be interesting to see stability with all of the nested feedback around the output Q.
Indeed, that's another point of concern. The amp of fig.12 for example, has a phase margin of only 50 degrees (seen at the output). Seen at the input it's much better: 94 degrees, but it is the lowest value that counts. So I definitely have to improve this figure, at least to 60 degrees.
E.
Old 10th May 2012, 12:13 PM   #205
Originally Posted by Edmond Stuart View Post
Hi JCX,
E.
About how high? Presumably it's asymptotic, so plot of THD20 versus load Z would be nice, but otherwise just an approximate number for a reasonable load would help .
Best Wishes
David
BTW re. your earlier post - Scotland is british.
(Britain is Wales, Scotland and that bit in the middle)
Old 10th May 2012, 12:46 PM   #206
Indeed, it's problematic to do it with a conventional circuit, as too many stages are enclosed by the Miller loop. It will result in too much gain and too much phase shift. Perhaps one can tame such an arrangement by means of an additional massive lead-lag compensation, but most likely that is counter productive.
It's not obvious to me why it would be much worse with the conventional circuit. The IPS is identical in both. From the pre-driver onwards it is also (for comparison) identical. The difference is a Baxandall pair compared to, say, the usual VAS pair with the emitter follower before the CE.
If simulation results are very different I'd appreciate an explanation of why.
And if there is too much gain then perhaps it could be used beneficially via nested Miller compensation rather than create problems with massive shunt compensation. That's my main query. The differences in alternative shunt compensation placements is educational but for a fall-back option.
Best wishes
David.
I have a new collection of minor typos if you want them. Would you prefer a PM?
Old 10th May 2012, 01:02 PM   #207
Default Zi
Best Wishes
David
Hi David,
Zi = 770kOhms @ 20kHz was apparently too low, because THD20k = 21ppm
With a diamond pre-driver Zi = 96MOhms @ 20kHz and THD20k = 3.1ppm, which is okay.
That is, after Scotland became part of the Kingdom of Great Britain in 1706, right?
But my great^n granny lived in 16th century.
E.
Old 10th May 2012, 01:15 PM   #208
R Dijk is offline R Dijk  Norway
Any thoughts abt adding an inner current mirror to the long tail pair?
Old 10th May 2012, 01:15 PM   #209
Great Britain, UK, British Isles, etc. all have their own quite precise but different definitions.
The green & blue Euler diagram depicts it well. It's about half way down.
British Isles - Wikipedia, the free encyclopedia
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 10th May 2012, 01:35 PM   #210
Best wishes
David.
Hi David,
I'm afraid we are at cross purposes, aren't we? I thought you meant by 'a conventional circuit' something like the 'blameless' IPS and VAS, including a 'beta enhancement' tranny. It's this circuit that is incompatible with input inclusive compensation (at least, without additional measures to tame it), because the compensation encloses too many stages with gain.
The current gain of the Baxandall pair is just 1x, while the current gain of usual VAS pair with EF is about 10000x. That's a huge difference.
Anyhow, please correct me if I misunderstand you.
Yes, please!
E.
Bogen Front End lpd Tubes / Valves 2 5th March 2008 05:12 AM
NE5534 with a new front end ...anybody? ashok Solid State 9 2nd June 2006 02:30 AM
My New Front End Pics! micb Car Audio 1 26th May 2006 03:26 PM
Noisily front end mantistube Analogue Source 10 16th January 2006 02:57 AM
Front end for sub amp mashaffer Solid State 9 22nd July 2005 04:35 AM
Copyright ©1999-2017 diyAudio
