Old 3rd April 2012, 06:21 AM   #21
p10ness is offline p10ness  United Kingdom
Thanks folks I'll poke around some more. Have ordered parts as suggested too.
Old 7th April 2012, 03:14 PM   #22
Guys
I changed Q401, Q403, Q405 and pretty much all semiconductors as suggested and also the 139 again.
I've also had to repair the track as I damaged it with all the putting in and ripping out again, looks as if they're not designed for that though.
The amp now runs ok at full line voltage.Voltage measurements seem similar for both side now too. I've set up the centre voltages, but the idling current on the previously blown side does not seem to be adjustable. The pot is ok.
With the solder shorts removed as per instructions one channel (the one that was ok to start) is adjustable but the 'repaired' by me side is not. I cannot see any voltage across the testpoints.
Having said that, the unit has been running at a high volume for over an hour now and seems to be performing ok on both sides.There is no sign of overheating.
Thanks to all that have been kind enough to offer guidance to me. If anyone would like to comment regarding the idle current adjustment I would be interested.
thanks
Paul
Old 7th April 2012, 05:17 PM   #23
jaycee is offline jaycee  United Kingdom
As you have now added emitter resistors to the amp, forget the solder shorts that measure over the 1R resistor. Instead, measure the voltage drop over one of the emitter resistors. From that, you can calculate your bias current. Vdrop / Remitter = Ibias. The original instructions suggest 28mA of bias.
It should change when you turn R443. If it doesnt, something is wrong. Q409, with R439, D405, R441, R443, R445 form what is called a VBE Multiplier or "amplified diode".
Basically, it's a constant voltage source. The idea is that it biases the output transistors on slightly to avoid the crossover region - i tend to think of it much like the idle speed of a car engine.
Another crucial part is that the VBE multiplier provides thermal feedback. You will see that the BD139 used is attached to the heatsink with the power transistors. This is so as the outputs warm up, the bias is kept constant. If it was not there, the result would be thermal runaway - as the transistors heat, the bias current would increase, until the output transistors overheat and fail. This is why you need to be sure that the VBE Multiplier stage is working correctly.
Old 7th April 2012, 09:27 PM   #24
Thanks again jaycee. Time for another poke-around then it seems. I must say I'm becoming quite interested in amps...I'll be looking up VBE theory to fully understand what's going on too.
Old 7th April 2012, 11:32 PM   #25
I'd recommend a good look at Rod Elliot's various articles: DIY Audio Articles
Old 8th April 2012, 09:08 AM   #26
Thank you
Old 9th April 2012, 08:18 PM   #27
Great job staying with it and not giving up until you found the answer! Looks like NAD has sucked another person into DIY...
I second jaycee's recommendation to read Rod Elliot. When you're ready for the next step, Bob Cordell's book does a fantastic job of being informative and useful to experienced engineers and simultaneously accessible and understandable to beginners.
"We monitor many frequencies. We listen always. Came a voice, out of the babel of tongues, speaking to us. It played us a mighty dub… "
Old 10th April 2012, 07:43 AM   #28
I've started reading Rod Elliot now, and very interesting it is too, easy to lose hours looking at the monitor! I'll be checking out Bob Cordell as well...so many things ...so little time...
Thanks very much everyone.
I'm just eying up a function generator and having a look for a new scope, my scope is 30 years old and rather creaky now. so many to chose from....
Old 21st October 2012, 11:02 PM   #29
Had a lot of these amps ,always seem to blow up every 10 years ,the 2SD669A and the 2SB649A transistors are in stock at electronic component suppliers and distributors, Nikko Electronics for semiconductors, transistors, capacitors all major brands of spare and replacement parts ,search for 2SD669AC ,both 5A fuses blown , 2N3055 S/C ,,2SD669 S/C collector to emitter ,
i replaced the 2SD669A with an exotic part until i get the parts from Nikko ,works fine
anyone know what the bias current is ? i can measure it across the 0.33 R emitter resistors
Old 8th March 2013, 09:07 PM   #30
tyger23 is offline tyger23  United States
Hi All!
I know this thread is old, but it was extraordinarily helpful to me while I was repairing my 7220PE. Like the 7225 and the 701, the 7220PE shares the old 3020 power amp section, reference designators and all.
Like p10ness, when I completed my transistor swap, I too was experiencing 0mV offset while trying to set the idle current of the newly restored channel. However, I did figure out the problem.
The new devices I used apparently need just a smidge MORE current to turn on than the original drivers and output stages.
So, I needed to change the "battery" circuit slightly. The original design shows a 100-ohm resistor in the R441 and R442 locations. While this works great for the original components, my newer components did NOT turn on at idle with this vale.
So, I changed R442 of my previously blown channel to a 68-ohm resistor. This allows more current through the "battery" circuit and the newer devices turn on properly at idle. With this change, I was able to properly set the idle current.
FWIW, I used MJ15022/23 output transistors and KSA1220A/KSC2690A drivers. I also replaced all the other transistors in the circuit with the lead-free "G" versions. Finally, I also replaced all the electrolytic caps in the power amp and preamp sections with Elna Similic 2 or Nichicon FG caps.
For now, I've got one channel left as original and one channel with all the above changes. I'm going to let things settle in for a few days on the new caps and transistors, then I'm going to do an "old-school" versus "new-school" comparison. Basically, I want to find out if changing the FETs and caps to newer, modern audio devices really makes the big difference.
I'll report back when I have more details, but I just wanted to make sure anyone who reads this thread in the future knows how to fix the 0mV biasing issue after changing the FETs.
Help NAD 7225PE (3020) receiver output transistors replacement vaslejean Solid State 12 21st May 2013 10:00 PM
Slow failure of NAD 7225PE. Suggestions? riotpack Solid State 31 23rd November 2011 11:07 AM
NAD 7225PE schematic wanted Agent327 Solid State 2 16th February 2007 07:52 AM
nad 7225pe receiver power envelope karma Everything Else 3 27th January 2005 12:34 AM
Nad NAD C162+C172 diagram(schematics) Bgt Solid State 9 16th January 2005 10:04 AM
Copyright ©1999-2013 diyAudio
