DC offset
DC offset
Old 26th March 2012, 01:55 PM   #21
godfrey is offline godfrey  South Africa
Originally Posted by swordfishy View Post
Wow, you whip these things up in an instant!
Nope. I was mulling this over yesterday, but hadn't got round to drawing the picture yet.
I wonder how a fet based version would work, in keeping with the overall theme of this design?
Probably very well. That's (part of) what John Curl used in the Blowtorch preamp. His reason was that the smaller cap values allowed him to use good plastic film caps, instead of electrolytic.
edit: The high output impedance of the FETs meant he ended up using separate regulators for every stage of both channels. That was just the final stage of regulation, too!
...the supposed sonic penalty of capacitors...
Sometimes it's hard to make sense of audiophile lore. e.g. It seems to a classic case of doublethink to simultaneously believe:
A) Any capacitor in the signal path severely degrades the sound quality, and
B) Valve amps sound great,
given that valve amps generally have more caps in the signal path than you can shake a stick at.
I'll think about the rest and try post later.
Old 26th March 2012, 04:36 PM   #22
R.I.P.
Swordfishy.
Look at the multiplier.
Imagine for this first thought process that no output current is flowing.
Vc3 = Vc4 = Vc2 - VbeQ1
Vc2 = 33/34 * Vc5
With pure DC (no ripple) you can determine the output voltage relative to the input voltage.
Now assume the multiplier is perfect.
Add some ripple to the Vc5.
If you decrease the voltage on C5 so that VceQ1 < VbeQ1, then the multiplier transistor is becoming saturated and the multiplier action is becoming steadily worse. Much worse.
You can predict when the Vce < Vbe by looking at that 33/34 (R1 & R2) ratio.
In the general case (not perfect multiplier action)
If the ripple causes +-2% variation on C5 then the multiplier works.
If the ripple is less than +-1% variation then the multiplier works better (because the hFE is higher).
If the ripple exceeds +-3% variation on C5 then the multiplier becomes nearly useless. (because hFE approaches single digit values).
If you want your multiplier to be effective with a high ripple input then you increase that 1k:33k to 1k2:33k or 2k:33 etc.
What you must avoid, for effective multiplier action, is the voltage on the collector of Q1 approaching the voltage on C2.
regards Andrew T.
Old 27th March 2012, 01:18 AM   #23
GregH2 is offline GregH2  Australia
GregH2's Avatar
Thanks Andrew, I understand what you're saying and I can see that you're right. I'm not sure I want to go the cap multiplier route anyway and to be honest I really like the idea of a simple CRCRCRC filter for the input stage. It seems more in line with the raw approach of this design.
In the meantime, I am thinking of replacing the output stage with a pair of the devices I discussed here:
Triodey transfer curves
I think these devices would be a natural in a circuit like this.
Old 27th March 2012, 10:15 PM   #24
Originally Posted by GregH2 View Post
3) By running a single rail, I could use two off the shelf transformers (one HV and one LV) with dual windings and have a dedicated winding for each channel and almost full dual mono construction. This lightens the requirements for preventing the crosstalk you mentioned above.
Or just one transformer with a separate winding for each channel, and voltage doublers / triplers for the higher voltages.
Soooo, as much as it is tempting to always go more complicated, the single rail version is looking pretty promising. The only problem is that turn on thump, which I need to go model I think.
You can organize effective speaker protection with a relay across the output, so the output cap charges and discharges through the relay, not the speaker.
Old 27th March 2012, 10:37 PM   #25
AKSA is offline AKSA  Australia
A few words on cap multipliers.
They leverage the capacity of a smaller, high Q cap with semiconductor devices to make a larger, virtual capacitor.
Fundamental to this is the overlay of the active device transfer function on the smaller cap.
I have an uneasy feeling about this, since clearly this transfer function cannot match the very smooth transfer of a cap, even an electrolytic.
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 28th March 2012, 09:25 AM   #26
R.I.P.
Aksa,
think about it as a Zener replacing that high Q cap (C5) you refer to.
Now you have a voltage regulator using the Zener as the reference voltage and the output is dependent on the Vz and Vbe of the pass transistor.
The capacitor multiplier works in similar fashion, the output voltage is dependent on Vc5 and Vbe of the pass transistor.
The BIG difference is C5 holds the average of the input voltage, whereas the Zener tries, quite poorly, to hold a fixed voltage.
If one can design a Zener regulator to perform well in the circuit then one should be able to design a cap multiplier to perform just as well in that circuit. I think the cap multiplier is capable of better performance than the Zener regulator.
regards Andrew T.
Old 28th March 2012, 09:31 AM   #27
GregH2's Avatar
Hi Guys,
Thanks all for your input, I have been meaning to get the cap multiplier into the simulator to test it, but unfortunately have been working 12 hour days this week. Hopefully I can get into it on the weekend. One thing I have decided though is to replace my output stage with some of those mega mosfets I linked above. I'm thinking of running them at up to 50W a piece! Just cause I can
Old 29th March 2012, 07:13 AM   #28
GregH2's Avatar
Default Very Nice
Well,
I finally had the chance to simulate the cap multiplier and I must say I am very impressed by the performance of such a circuit. What a great way to get a smooth supply with minimal power dissipation.
I tried it with a mosfet as the active device, but did not get very good results. The BJT is clearly superior in this application. Ultimately this is the circuit I came up with, the ripple is so close to zero it's not funny.
Any thoughts on the suitability of this circuit, and am I missing anything?
Thanks for putting me on to this, it really is a great way of doing things - non linear performance aside.
Now to see how it sims in circuit.
Old 29th March 2012, 07:28 AM   #29
GregH2's Avatar
Oops, looks like my simulation parameters were wrong. With about 88v input and 4v p-p of supply ripple, it produces an output voltage of about 80v with 0.2mV p-p of ripple.
Old 29th March 2012, 08:04 AM   #30
It has it's limits. Even if the base voltage is held completely constant, there will be some ripple at the output due to Early effect.
That double RC gives it a really slow rise at start-up. After 2 seconds, the output voltage is almost 1/2 way there!
DC offsetHide this!Advertise here!
DH-220 Clone (SMART TA-242) can't adjust DC offset using offset bias pot? beady Solid State 6 17th March 2011 10:53 AM
DC Offset JannaCassandra Chip Amps 3 26th July 2008 03:20 PM
Zero DC Offset nitin Solid State 3 6th January 2005 05:28 PM
Help With DC Offset Sybex23 Chip Amps 8 15th November 2004 07:11 PM
DC offset need help again :-( djdamix Solid State 13 26th October 2004 08:38 AM
