marantz pm66se no lights
Old 21st March 2012, 08:19 AM   #1
chris212 is offline chris212
Default marantz pm66se no lights
My pm66 shows no lights on the facia when switched on. The heatsinks and output transistors all get warm, and the source direct relay clicks when the button is pressed but the output relay doesn't click into life as it should.
I have replaced the suspect r807 47r which was faulty, tested all the other resistors I can see [I think!] And replaced the 2 big main caps with 12000uf 63wv ones, but still no lights or relay click.
Can anyone give me any help or advise as to what it could be? Thanks.
Old 21st March 2012, 10:01 AM   #2
Coconuts 500 is offline Coconuts 500
Burnt out bulbs?
Old 21st March 2012, 10:39 AM   #3
east electronics is offline east electronics  Greece
east electronics's Avatar
you need to verify that all voltage is present according to the schematic where highlights will be he secondary power supply that is located on board P851 there is a regulator there and a transistor circuit for 5 and 24 volt
then you need o verify voltage on board PU01 ( front board) check also LU01 and so on
carefully though it can be complicated
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 12th April 2012, 10:08 PM   #4
still no lights or relay click. When I switch it on the transformer makes a louder than usual humming noise. It sounds like something is putting a drain on it. The fuse will blow eventually, but not immediately. Only kept it on 5 secs incase it is doing futher.damage. Any advice appreciated. Thanks.
Old 12th April 2012, 10:40 PM   #5
sgrossklass is offline sgrossklass  Germany
Sounds like is some serious current flowing, which is never a good sign. Next thing to do would be fashioning a bulb tester and checking voltage and current levels in both channels of the power amp.
marantz pm66se no lightsHide this!Advertise here!
Marantz PM66SE Brian_x Solid State 109 17th March 2012 12:04 AM
Marantz pm66se paulsoulsby Solid State 1 7th August 2009 08:26 PM
Marantz PM66SE mods? insomniac Solid State 0 22nd June 2004 01:22 PM
Copyright ©1999-2017 diyAudio
