Denon PMA-757 - Can it be fixed? - Page 2 - diyAudio
Old 21st March 2012, 05:14 PM   #11
Default Also look here
You may get additional information and help here:
AudioKarma.org Home Audio Stereo Discussion Forums - Powered by vBulletin
I was so much older then, I'm younger than that now.
Old 23rd March 2012, 10:27 AM   #12
Just put in 5050 LED chips (because of their wide dispersion of light + they were just laying around in my house) with an appropriate resistor to reduce their intensity and it's working like a charm. Will go into the sonic parts when I have more time and get the components. I had the feeling the left channel is a bit weaker, could this be due to the volume pot? The seller did say the left and right were sort of on and off when changing volume and that it needed some fiddling with to get both playing sound...
Thanks all!
Old 22nd May 2014, 07:56 PM   #13
Karl vd Berg's Avatar
Cool Oh, oh!
Another situation here...
I've got this model too, few days ago. Everything was fine... until some 10 minutes ago!
Left channel seems to be suddenly attenuated a bit at times. Channels are not equal for a brief moment. The right channel remains good and loud, but the left one, at times, is not "punchy" as it should be...
I tried now Tuner/Aux/DAD and it's the same problem.
Power caps?
Old 22nd May 2014, 07:59 PM   #14
Mooly's Avatar
Speaker relay contacts tarnished (its a common problem) or a dry somewhere.
Installing and using LTspice IV. From beginner to advanced.
Old 22nd May 2014, 08:11 PM   #15
Yes!!!
The relay!!
Man, for a while I nearly had something!
Old 23rd May 2014, 02:09 PM   #16
pdul is offline pdul  Denmark
Clean the switches and pots inside
Old 23rd May 2014, 11:19 PM   #17
I did it when it arrived
Running the PMA-737 while I replace the relay.
Denon PMA 2000RIV Al Raj Solid State 33 7th June 2013 06:06 PM
Denon PMA-700AE stewdaddy Solid State 0 5th April 2010 10:37 PM
Denon dvd-757 opamp replacement and coupling question cltaylor Digital Source 1 25th July 2007 02:34 AM
Denon PMA-2000 Skorpio Solid State 3 14th February 2005 01:48 PM
Denon Pma-860 ManUtd Solid State 4 11th January 2005 09:14 PM
Copyright 1999-2017 diyAudio
