New IR Control Design
Old 31st May 2004, 09:54 PM   #21
ALBQ is offline ALBQ  United States
Default Schematic
Algar_emi,
Here is a first pass at a schematic for the BS2 section with motor driver, function relay drivers, IR detector and LCD display. With this, you should be able to get the basic circuit up and running. You will need to adjust the baud and begin/end-of-line info for the serial LCD display - once the baud/line settings set, circuit should work with any serial LCD display. Keep me posted and I will try and help.
Cheers, -ALBQ
Old 31st May 2004, 10:04 PM   #22
Default BS2 Board Pic
Algar_emi
Picture of BS2 board of education, IR detect and Serial LCD display (Scott Edwards unit I used in developing the circuit)
Cheers -ALBQ
Note - Had to play around with the baud settings to get this to work and begin/end of line is not setup correctly for this LCD display - not as many characters and different baud settings than the one used in my preamp
Old 31st May 2004, 10:05 PM   #23
Default Another BS2 Pic - top down
Yet another picture - top down
Old 1st June 2004, 12:32 PM   #24
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
Great . Finally someone has the time to get along with the project . Keep us posted.
Bye
Old 1st June 2004, 12:46 PM   #25
Algar_emi's Avatar
Hi ALBQ. How about the rest of the circuit. Your preamp seems to be very nice. I'm still searching for a nice tube preamp to build this winter. Thanks again.
Old 1st June 2004, 04:57 PM   #26
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
I have one of these now :O )
http://www.optrex.com/Products/PartD...1505NFQJ-LR-AG
Old 2nd June 2004, 03:28 AM   #27
Default That will look pretty
JasonL,
That is a very nice looking display. When I ever get around to building another preamp, I was thinking about using a VFD display. They look great but, when I build my last preamp, I was behind schedule and way over budget (which my spouse reminded of me daily). Think the display you are buying will look really good. Also, on my preamp, the display and IR detector are behind a smoked plexiglas panel (see attached link). Reason I mention this is that tint/color, can make a world of difference. When my preamp is off, panel is totally black but, lights ups wonderfully when the display back light is on.
Enjoy, -ALBQ
http://mywebpages.comcast.net/gilles...U7-Preamp.html
Old 2nd June 2004, 03:40 AM   #28
Banned
I already bought mine. : O )
Old 2nd June 2004, 03:45 AM   #29
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
I have one of these too, and it isn't a very bright unit. It is hard to see from across the room. I guess this is what you get for a $20 unit... I am hoping to find an organic lcd that is brighter, and has better viewing angles.
Brian
Old 2nd June 2004, 03:59 AM   #30
Default If you can afford it, VFD is the way to go
Brian,
IMHO - The best looking displays are VFDs. They cost a bunch when wired for a serial interface so you can hook them to a standard serial port (an standard power to for that matter) but, oh they are bright and look great
Cheers -ALBQ
http://www.matrixorbital.com/pages/products.asp?CatID=2
New IR Control DesignHide this!Advertise here!
Tube eq or tone control - how to design it? marz.tv Tubes / Valves 5 20th July 2009 01:01 AM
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 04:12 AM
The "Leap-Frog" Method Of Switching Amplifier Control Loop Design analogspiceman Class D 29 1st December 2006 04:21 PM
I have a pair of JBL control 5 speakers, which valve amp design you recommend? ultrapato Tubes / Valves 4 21st July 2005 04:25 AM
Help: how to design temperature control for heating mantle Prune Parts 1 17th February 2005 11:27 PM
Copyright ©1999-2017 diyAudio
