Sansui G-5000 problem
Old 17th March 2012, 11:31 PM   #1
Hodgie is offline Hodgie  Australia
Default Sansui G-5000 problem
Hi all,
I'm looking for some advice to a non-technical person (that's me!) about an issue I have with my Sansui G-5000 tuner/amp. I have owned the amp for about 3 years with no issues - and subsequently no maintenance. Recently, the amp has started to lose the connection to the left channel, but only when using the tuner.
I initially thought it may have been my speakers, but swapped out the speakers and the problem persisted. It was only fluke that I discovered that the problem only appeared with the tuner - ie. worked ok on CD (AUX) connection. I haven't tested phono connection.
I do wonder if this is coincidental - the amp had warmed up a little when I swapped to AUX, so keep that in mind.
Issue seems to be intermittent, although more consistent lately.
Is it likely to be just a leaky cap somewhere, and if so, how does a non-technical person identify this easily? It is likely that I will need to take it to a tech somewhere, but would like to have some possible causes identified in advance if I can.
Thanks in advance for any advice, Hodgie
BTW I'm located in Southern Highlands south of Sydney, so anyone with suggestions on a good local tech around either Highlands, Wollongong or Campbelltown NSW, that would be great . Cheers.
Old 18th March 2012, 12:38 AM   #2
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Sounds like the switch for the tuner.
Clean it with some contact cleaner.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Sansui G-5000 problemHide this!Advertise here!
Need help with Sansui 5000 gwyz Solid State 79 29th August 2016 05:52 AM
Sansui SP-5000 Kensai Multi-Way 4 6th June 2012 09:20 PM
Sansui BA 5000 Loud pop at turn on / off VintagePlus Solid State 20 24th December 2011 04:13 PM
Sansui BA-5000 Oscillation EchoWars Solid State 48 11th June 2009 11:36 PM
ETI 5000 problem AlexRWard Solid State 14 13th February 2008 09:00 AM
