New Doug Self pre-amp design... - Page 64 - diyAudio
Old 23rd October 2012, 02:27 AM   #631
Art M is offline Art M  United States
Default 1Kohm V.S 10Kohm
In a very general sort of way, how much worse would performance be if I used
10Kohm controls and scaled the requisite component values ? Often I prefer to use
what parts I have at hand.
Old 23rd October 2012, 02:40 AM   #632
noddy55's Avatar
Now if one end of the pot is connected to the wiper the situation will be different,..............
I request's you to please explain, What will be the situation here? Both, when (1k resistor shunts the pot as well as when two pairs of 560 ohms shunting the pot).
What's wrong with using, 560 ohms pair with 10K pot, if its ok in every way?
Please, do consider, that i want to use a linear pot.
Thanks.
Old 23rd October 2012, 02:52 AM   #633
noddy55's Avatar
Incidently, my preamp that uses this relay attenuator is my favourite for sound quality. It has a single non-inverting gain stage after the attenuator using a discrete opamp that is based on the Figure 3.33 circuit in your Small Signal Audio Design book, but with the addition of a current mirror in the input stage and some tweaking of bias currents etc.
Can you please tell me the actual brand, model and make of your favourite preamp?
If it's your self made then, can you please, post its schematic? I feel it's worth building one to feel the magic.
I would love to hear the sound you love.
Thanks.
Old 23rd October 2012, 06:43 AM   #634
Mooly's Avatar
The noise factor of the preamp will be slightly worse (slightly as in on paper). A real benefit is the loading on the opamps is reduced substantially.
Dougs older "1996 precision preamp" was more complex than this one and used the higher impedance values. It was ultra quiet too. You won't hear any difference noise wise.
Old 23rd October 2012, 06:46 AM   #635
Mooly's Avatar
Thanks.
Not sure who you are quoting here but didn't we cover this in post #600
Old 23rd October 2012, 07:41 PM   #636
DouglasSelf's Avatar
The noise performance would be significantly worse. Exactly how much worse I cannot say without doing the experiment.
The whole essence of the preamplifier design is that it shows how to use 1K pots without resorting to the complications of discrete circuitry to drive the low impedances. To build it with 10K pots is to really miss the point.
Douglas Self
Old 24th October 2012, 07:40 PM   #637
noddy55's Avatar
Please, see post 605 by Mr.kevinkr.
Thanks.
Old 25th October 2012, 06:48 AM   #638
Mooly's Avatar
Thanks.
See the last part of the reply in kevinkr's post... "the situation will be different, but the taper resulting from such a connection would not be the most useful I could think of."
So it's OK apart from the "taper" or law of the pot. What that means is that rotating the pot a few degrees will not give the same change in output voltage on the wiper as a pot with no resistors connected to the wiper. You would find all the "action" happens very close to each end of the rotation.
Old 25th October 2012, 09:26 AM   #639
Hi Noddy55
Off-topic, but if you want to understand and minipulate potentiometer law (taper) with external resistors, try this article, which covers most issues. Potentiometers (Beginners' Guide to Pots)
Ian
Old 3rd November 2012, 06:34 AM   #640
owdeo is offline owdeo  Australia
Thanks.
Well as I said it's basically Self's discrete opamp circuit as published in his book. Although most of the component values I ended up with are different I think I would still be breaching copyright by posting the schematic as the topology is the same. I recommend getting a copy of the book - it's excellent.
The circuit is basically a Lin toplogy - degenerated LTP input with current mirror, simple common emitter VAS (I tried both darlington and cascode enhancements and found they made the sound worse), and single-ended emitter follower output stage with constant current source (again I found complementary push-pull sounded worse). I suppose the differences in sound quality I heard with the different configurations came down to the distribution of harmonics, but I have no way of measuring distortion that low. I could see it in Spice though.
Would Mr Self object if I posted my simulation schematic here given the component values are different? IIRC he had the circuit free to view on his old website so maybe he won't mind. If he doesn't I will post it.
Doug Selfs NE5532 Power Amp. Thoughts anyone ! Mooly Chip Amps 218 17th July 2016 10:00 PM
blameless amp and doug self streetera Solid State 17 16th July 2007 10:06 PM
4th Ed. of Audio Power Amplifier Design Handbook (Doug Self) nickds1 Solid State 4 9th November 2006 12:02 PM
Doug Self Advanced Pre Amplifier PCBs macka Swap Meet 0 9th October 2006 07:41 AM
Help me design pre-amp PS hardcore Tubes / Valves 7 10th November 2004 06:32 AM
Copyright 1999-2017 diyAudio
