New Doug Self pre-amp design... - Page 5 - diyAudio
Old 18th March 2012, 09:09 AM   #41
jan.didden's Avatar
Originally Posted by Joachim Gerhard View Post
Jan, you know that in the FPS i use 2 x 4 NE5534A in parallel symmetric inverted. That way i get very low distortion, low noise and tremendoes current drive.
One advantage of the NE over the LME is that it has 1/4th of the current noise. That can be important when you use it at impedances over 1kOhm for example an MM input. There it beats the LME in noise but not used as an MC input where the LME is better but not optimum. There you need AD797, LME49990 or such. There is VOLTAGE and there is CURRENT noise.
Good points Joachim.
What I meant with an earlier post, and what you are also saying, is that you should select your devices with the application and use in the circuit in mind.
For that, you need to read the article (any article) and understand the author's reasoning.
It is possible that you put more weight to one issue or another and that you make a different choice, but it's hard NOT to learn from other's ideas.
jan
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 18th March 2012, 07:37 PM   #42
diyAudio Member RIP
Originally Posted by abraxalito View Post
Yes it is. ( This could go on ad infinitum )
Tedious but I'll bite the bullet. Why don't you suggest alternatiive op-amps
that "should" be better in this design and reasonably justify your opinion.
rgds, sreten.
Old 19th March 2012, 12:10 AM   #43
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
I could only suggest opamps that sound better if I actually built the design and listened to different opamps. I have no need of a preamp so that'll never happen.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 19th March 2012, 12:24 AM   #44
a.wayne is offline a.wayne  United States
Sin Bin
Don't like the turnover points selected on the tone control circuits . I would prefer 50 hz instead of 100 currently used for the bass, 12 k. Instead of 10k for the highs .
10k is somewhat acceptable , the 100 hz is completely useless and while I favor full discrete designs, Im not against IC arrangements , especially since it allows one to op-amp roll , good when wanting play around with different opamps.
Old 19th March 2012, 01:29 AM   #45
I really like the circuit design. But then again I like the good'ol NE5532. It's a great part! But the published PCB layout could definitely be improved.
Best Regards,
Carl Huff
Old 19th March 2012, 05:15 AM   #46
gannaji is offline gannaji  India
Will you kindly explain why you prefer those values?
www.samritatrust.org
Teach me the glorious lesson that occasionally, I might be mistaken. Keep me reasonably sweet.
Old 19th March 2012, 03:04 PM   #47
hags is offline hags  United States
I see why designs by Curl, Pass, Hansen, et al, sell and designs by D. Self are found mostly in books and magazines.
"Some lures are designed to catch fish, others are designed to catch fisherman."
Old 19th March 2012, 03:40 PM   #48
danielwritesbac's Avatar
a.wayne wants to turn up the bass at 50hz, not the boom at 100hz.
7k to 10k treble boost is raspy, above this, such as ~12k is airy.
Ears (and many speakers) have the least performance at the farthest extents of the audio band, so if the tone controls have a limited number of selections, it would be good to do the most important things first. . . otherwise the tone controls could be really unimportant, and possibly counterproductive.
Well, it all depends on what you want. Doug Self's tone controls look like they're meant to be dialed down for LP rumble and hiss filter, not dialed up for ear contour.
Old 19th March 2012, 03:57 PM   #49
jan.didden's Avatar
Actually, I'm sure Self's designs sell quite well, it's just that his name is not on them ;-)
jan
Old 19th March 2012, 04:41 PM   #50
Sin Bin
Good response ...
jan
Jan,
Could you name a few....?
Doug Selfs NE5532 Power Amp. Thoughts anyone ! Mooly Chip Amps 218 17th July 2016 10:00 PM
blameless amp and doug self streetera Solid State 17 16th July 2007 10:06 PM
4th Ed. of Audio Power Amplifier Design Handbook (Doug Self) nickds1 Solid State 4 9th November 2006 12:02 PM
Doug Self Advanced Pre Amplifier PCBs macka Swap Meet 0 9th October 2006 07:41 AM
Help me design pre-amp PS hardcore Tubes / Valves 7 10th November 2004 06:32 AM
Copyright 1999-2017 diyAudio
