#421 | |
Is there a potential problem in using standard ribbon cable for this pre-amp solution? It is being suggested by Elektor or Doug Self. Or, should I attempt to weave 10 individual wires from the pins of the sockets. The former suggestion seems to be the easiest, but maybe not the best in terms of sonics? What issues should I be concerned with when using ribbon cable with a DAC? |
#422 |
Quote"It's no good listening after immediately swapping parts because you are not in the right frame of mind""
It's called expectation bias. |
#423 | |
Kindest regards Nico |
#424 | ||
![]() Quote:
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#425 | |
![]() The ribbon cable in the 2012 preamp is only used for control signals to switch the relays so can't affect SQ - you'll know if there's a problem if your input switching starts going haywire. For the signal connections in your preamp between the boards I would suggest using sheilded audio cable to minimise induced hum/noise from the power transformer and surrounding environment. Don't use ribbon cable! |
#426 |
If you are using headphones to do comparative listening tests, try a 47 to 100 Ohm resistor in series with the headphones.
#427 | |
Where is the KISS approach here!It's late here so I'm going to bed.
#428 |
Somehow I don't think the KISS principle is what this design is all about
![]() I know it seems redundant but there may have been a reason for using a 4 pin header when a 3 pin would do: once you start trying to solder or crimp shielded cable braid into those pins for the 0.1" header sockets you'll see that soldering two braids onto one earth pin can easily make it too fat to fit into the connector housing in which the socket pins are housed. I'd rather have the 4 pins, one for each wire. |
#429 |
At what frequency is that ?
Crossover shows more at higher frequencies. |
#430 |
It may run out of class A in certain conditions but the high feedback will erode most of it so measurements will still be clean.
Some time ago i measured how much class A certain Opamps have. You can put a low value resistor, say 50 Ohm, from the output to ground. Then you put say 10 Ohm resistors into the voltage feed to Pin 4 and Pin 7. You then increase the input voltage of a 1kHz signal ( can be 10kHz or higher ) until the current goes up that flows into the Opamp from the PSU. The 10 Ohm resistors function as sensors by measuring the voltage over them. I would say that the LME49710 has around 2mA class A. When you drive a 600 Ohm load it will leave class A at 1,2V. |
| Doug Selfs NE5532 Power Amp. Thoughts anyone ! | Mooly | Chip Amps | 87 | 15th June 2012 08:08 PM |
| blameless amp and doug self | streetera | Solid State | 17 | 16th July 2007 10:06 PM |
| 4th Ed. of Audio Power Amplifier Design Handbook (Doug Self) | nickds1 | Solid State | 4 | 9th November 2006 12:02 PM |
| Doug Self Advanced Pre Amplifier PCBs | macka | Swap Meet | 0 | 9th October 2006 07:41 AM |
| Help me design pre-amp PS | hardcore | Tubes / Valves | 7 | 10th November 2004 06:32 AM |
