New Doug Self pre-amp design...
Old 29th August 2012, 05:57 PM   #561
redjr is offline redjr  United States
Originally Posted by dtharper View Post
I have determined that no 1k stereo (dual gang) linear pots with a .5w power rating exist affordably in north america. omeg has no dealers that i can find, vishays at newark are only available from farnell for a $50 shipping charge. no one has the bournes pots in stock. alps doesn't make 1k. man oh man. i am frustrated!
Yeah. It's a real bummer. I just bit the bullet and ordered mine from Farnell along with other components. At least the shipping was spread out over some of the other parts I needed. But in the end, this project will be expensive and hopefully worth it.
redjr
Old 29th August 2012, 06:05 PM   #562
Kindhornman is offline Kindhornman  United States
Kindhornman's Avatar
A question for the group here. I have been reading through this thread and I am wondering where I can get a copy of the schematic for this pre-amp, and also where one could procure a board to build one of these devices? I am trying to figure out which volumes of the Linear journals I would have to purchase to get the entire article and not just pieces. If Doug Self is reading this thread are you going to print another book and include all of this information in one place or is it already in your previous book on small signal devices? I would love to get in on building this and learning what is going on here and have no problems with 5532 chips or whatever is found to do the job.
Steven
Old 29th August 2012, 06:44 PM   #563
Steven -
The 3-part series of articles including all PCBs has been written up in several recent issues of Elektor magazine. Starting with the April 2012 issue. The first such article started here. If you are a not a subscriber, you can download the articles and parts list for a few bucks I believe. There are 6/7 different boards required for the full project. Gathering all the parts may take some time, but don't let that deter you. Newark/Farnell has most parts in stock, although the 1k pots generally have to be back ordered and are pricey. The PCBs themselves can be ordered directly from Elektor.
Personally, I have all the boards completed, but untested as I am waiting for a suitable enclosure before completing all the required internal wiring and ribbon cable requirements. It's unclear at this point whether Elektor will offer a nice, high-quality case. I'm hoping they do.
Rick
redjr
Old 29th August 2012, 07:01 PM   #564
Rick,
Thank you for that information. No I am not a subscriber but perhaps I should be? I see the link to the boards on that first page and there are it seems seven boards that need to be used for the complete preamp design. Is there a reason besides offering each board as a stand alone circuit that there is not a monolithic board with everything on a single board? Would that have any advantage to not having to string all the boards together with ribbon cables and are you better off using twisted pairs of wires in some of these interconnections rather than a ribbon cable and the parallel wires and inductive problems this could have? The magazine as single copies does not seem overpriced, I assume that a yearly subscription is much cheaper than individual issues.
Again thank you for the information.
Steven
ps. has there been any thought to a group purchase for those 1k pots rather than one at a time at the maximum price?
Old 29th August 2012, 07:06 PM   #565
dtharper is offline dtharper  Canada
Also it would appear that the 2sa1085e stock situation across all the usual suspects has dried up. paying $5 per transistor on ebay really stinks.
Old 29th August 2012, 07:12 PM   #566
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
Originally Posted by SY View Post
For balance, I usually have one of the servants stand in front of the louder channel's speaker.
So I guess if you use tone defeat you nail the servant in a fixed position?
Kindest regards
Nico
Old 29th August 2012, 07:14 PM   #567
I have an RFQ in with omeg to see what i will cost to get some on this side of the pond.
Old 29th August 2012, 07:28 PM   #568
dtharper,
From that description I am going to assume you are in England or across the sea....
Another question then. I was looking at the view of the PC boards and correct me if I am wrong, but are the boards created for all surface mount components? I see no holes and the spacing would lead me to that conclusion. Care to elucidate on that? I have never built anything with surface mount devices, looks a bit harder to accomplish without making a mess of it....
Old 29th August 2012, 07:29 PM   #569
dtharper,
canadian so across the sea
the project is all through hole.
Old 29th August 2012, 07:29 PM   #570
On Hiatus
SY's Avatar
That would be barbaric! I use cyanoacrylate and duct tape.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
New Doug Self pre-amp design...Hide this!Advertise here!
Doug Selfs NE5532 Power Amp. Thoughts anyone ! Mooly Chip Amps 218 17th July 2016 11:00 PM
blameless amp and doug self streetera Solid State 17 16th July 2007 11:06 PM
4th Ed. of Audio Power Amplifier Design Handbook (Doug Self) nickds1 Solid State 4 9th November 2006 01:02 PM
Doug Self Advanced Pre Amplifier PCBs macka Swap Meet 0 9th October 2006 08:41 AM
Help me design pre-amp PS hardcore Tubes / Valves 7 10th November 2004 07:32 AM
