Hybrid DIY cct of LM3886+6N11
Old 23rd March 2012, 10:16 AM   #11
copperweed is offline copperweed  United Kingdom
Originally Posted by nullbyte View Post
Haha, sweet! Looking forward to seeing what else you do with it, the 10uF cap mod seems pretty great. What transformer do you think will work with a regular sized heatsink? I might have a larger one lying around too, so I might emulate your setup a little. Also, bought it!
Nice one, nullbyte.
I'd have been happier trying a 30/0/30 200va first; that might not have tripped-out the speaker-protect, but I'm happy with the sound at 35/0/35.
Let me know if you face any problems.
One last time, to be clear. Link across C18 to disable trip-latch-off, then take C19 up to 15uF to avoid triggering the speaker-protection circuit.
WORDS OF CAUTION. THESE ACTIONS MAY VOID YOUR WARRANTY!!!
But in my case, I don't care.
What I like is that I've got a piece of kit that now scares me before I break it.
Old 23rd March 2012, 08:20 PM   #12
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
Is that 30-0-30 ac and 35-0-35 ac?
If yes, the LM3886 and 4780 peek to peek is supposed to be maxed at 80Vdc max...
30Vac = +/- 42Vdc and 35Vac = +/- 50Vdc which would bring you to 84Vdc and 100Vdc respectively on 120Vac or 240Vac primaries...
I guess you're playing with fire here...
I bought a PCB and stuffed it myself. It is running two LM4780 with an X10 buffer. Sounds really good but the LM4780 seem to be oscillating since they get pretty hot quickly... And the heatsink is way adequate... I've been looking at the 4780 spec sheet on what to do in that case but have not implemented anything yet...
Here it is
Every single parts in there is good quality and sourced through Mouser. Digikey and Parts Connexion.
If anyone is interested in fixing it (I don't have time, too many projects right now), just PM me!
Ciao!
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | USSA3 & 5 | FO v1.4 | TGM8 | VZ Audio NS OPS | NX Amp | FC-100
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 23rd March 2012, 08:37 PM   #13
Here it is
Ciao!
Do
Sweet, seperate tube buffers, high power output stage... whats not to like?
I think my meter is an auto-RMS; the DC is 35 across the caps!
And is yours oscillating, or are they passing Res-Cap-drained-rectified-DC?
Old 23rd March 2012, 10:04 PM   #14
"I guess you're playing with fire here... "
Um, yeah, that's my job.
Give me an envelope...
Old 23rd March 2012, 10:47 PM   #15
pinnocchio's Avatar
Hey copperweed,
I'm not getting the last part of this
Thanks!
Do
Old 24th March 2012, 12:47 AM   #16
pinnocchio's Avatar
Hi copperweed,
Not familiar with that expression... Sorry if I have insulted you.
Do
Old 3rd April 2012, 07:32 PM   #17
Pemo is offline Pemo  Mexico
Pemo's Avatar
Hi Copperweed, what do you think about the PSU is it enough. Are the caps big enough?
RGDS
PEMO
Old 3rd April 2012, 08:27 PM   #18
Hi copperweed,
Do
Not insulted at all. I admit I was pushing the SOAR envelopes of the chips. I'd be happier if it was 30/0/30 volts.
Old 3rd April 2012, 08:42 PM   #19
Hey copperweed,
Thanks!
Do
Sometimes, if the output stage has gone short-circuit, it can sound like it's oscillating at 50 or 60 Hz. The power has been transformered, rectified and smoothed, but then, if the smoothing caps are shorted to ground through the speakers, it can sound like a full-power oscillation. I need to know aprox frequency to be sure. Whistling or whining could be osc., but loud buzzing could be a blown chip.
Old 3rd April 2012, 08:56 PM   #20
RGDS
PEMO
Hi Pemo.
When it's loud (like, 75/80wpch), there is some compression, but if I had a regulated 30/0/30Vdc PSU @ 10A, or even 35/0/35 @ 10A, instead of a Tx on the end of the supply chain then I'd be a lot more satisfied.
You just CAN'T HAVE too much power supply...
Hybrid DIY cct of LM3886+6N11Hide this!Advertise here!
About an hybrid LM3886 amp using 12AX7 tube gaetan8888 Chip Amps 23 21st October 2015 09:59 AM
Can someone help me with DIY hybrid preamp? 2sk170 - 6dj8 - cascode mwmitchell Tubes / Valves 2 5th May 2012 01:17 PM
6N11 = 6N1P ? JoeDJ Tubes / Valves 7 16th May 2011 01:31 AM
Help needed with a diy hybrid esl badduh Planars & Exotics 29 10th January 2007 07:21 AM
MOSCODE hybrid DIY ckwong99 Tubes / Valves 0 5th September 2005 01:38 AM
