I have a Parasound 2200 MKI with the famous "bad relay". The left channel relay in this unit has an open coil, right side is fine for now. I still would like to replace both relays. The original replays are made by Koike electric part number HDI-48D-04. A simple 30A 48v SPST, PC mount. I would like to find a "drop in replacement" if possible to avoid mucking up the unit. My question is has anyone found a direct replacement for the relays or are they just wiring them up and mounting them to the chassis. I was going to call Tony at Parasound on Monday and see if he had any source but some here may have already been through this as this seems to be a common problem with this amp.
#2 |
I guess I’ll amend this myself. Speaker relays are available from Parasound, just call Tony. Also to clear up any question on the setting I’ve included the offset and bias adjustments.
#3 |
Not interested in selling this amp as is are you? I just need a single channel for my center speaker as I have a working HCA2200II for my L/R speakers. Thanks. Zac.
| How to mod a parasound hca 2200 mk2 ? | Søren Kramer | Solid State | 12 | 14th April 2013 11:43 PM |
| Parasound HCA-2200 problem - need some help | Muddler | Solid State | 12 | 28th January 2013 03:45 PM |
| Diffirent between Parasound 2200 and Mark ll | pwgtang | Solid State | 2 | 14th March 2012 09:38 PM |
| FS: Parasound HCA-2200 MKII | Zero Cool | Swap Meet | 3 | 22nd December 2007 08:15 PM |
| Need Schematic for Parasound HCA 2200 II | mjctech | Solid State | 2 | 15th September 2005 04:25 PM |
