LME49811 + 2SK1058/2SJ162
Old 13th March 2012, 01:10 PM   #11
pieter t is offline pieter t  Netherlands
Originally Posted by homemodder View Post
True. The bias voltage parameter for this chip is not given ....??
It's all in the LME49811 datasheet
Old 13th March 2012, 01:40 PM   #12
homemodder is offline homemodder  Portugal
Another quick look and Vbias not stated on datasheet. For 49830 it is. Offcourse it can be calculated but Im lazy.
Old 13th March 2012, 02:07 PM   #13
Buslik is offline Buslik  Belgium
Any case advices?
Old 13th March 2012, 03:02 PM   #14
For mosfets rather use the lme49830. For higher performance with the mosfets use small drivers. National application note 1645 gives some valuable tips.
Old 13th March 2012, 03:07 PM   #15
Maybe a bit slower look?
It's really there, even with different + and - supply voltages.
But as you are lazy: output swing is 33 VRMS with +/- 50 volt rails, and 68 VRMS with +/- 100 volt rails.
Old 13th March 2012, 03:18 PM   #16
The base to base, or gate to gate, bias voltage is not the same as the output swing.
regards Andrew T.
Old 13th March 2012, 03:26 PM   #17
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Where's SpittinLama when you need him? There's a chart of THD% vs bias current in the LME49830 data sheet. Best advice I can give is that the lateral MOSFETs don't need thermal compensation which is a big design simplification, secondly -- if you tweak the values of the gate stoppers on the MOSFETs you can reduce the THD% (which is already quite good.) This is illustrated in AN-1645. There was going to be another paper/application note on the compensation techniques for this series of drivers, but National decided to channel their resources toward solar power/alternative energy chips before that bubble blew up, and they got swallowed by Texas Instruments in the interim.
Old 13th March 2012, 03:41 PM   #18
I know Andrew; I guess that homemodder should look at bias voltages required for the output transistors. That has not so much to do with voltage swing of the driver. Important though is output current of the driver (is the driver capable of driving the input capacitance of the output device, where fets generally show higher input capacitance than BJT's - hence the LME49830 with it's much higher output current meant to drive fets).
Old 13th March 2012, 03:41 PM   #19
Interesting, TMC perhaps ??
Old 13th March 2012, 03:44 PM   #20
FETs are reputed to have similar capacitance drive requirement to BJTs.
The BJTs also need current drive for the base.
Generally this makes the drive requirement for BJTs more onerous.
regards Andrew T.
LME49811 + 2SK1058/2SJ162Hide this!Advertise here!
2SJ162-E and 2SK1058-E 1965GTO Vendor's Bazaar 5 7th August 2012 07:05 PM
Anyone know where to get 2SJ162/2SK1058 IN THE US Ivey Parts 8 20th November 2010 01:56 PM
Anyone know where to get 2SJ162/2SK1058 fossil2k Solid State 8 17th March 2008 01:07 PM
2sk1058 / 2SJ162 - 4 of each - aus only mikefromaus Swap Meet 0 24th January 2008 02:27 PM
2sk1058 2sj162 search sparkle Parts 6 24th June 2007 07:24 AM
Copyright ©1999-2017 diyAudio
