Another of Ken's bizarre circuits
Old 9th March 2012, 04:17 AM   #1
kenpeter is offline kenpeter  United States
Default Another of Ken's bizarre circuits
This could be a front end with inverting or non-inverting VAS...
Distortion is really really low, given the simplicity and nothing
fancy parts. Second harmonic -120db down for smaller signals.
Anyways, mo' crazy abuse of shunt tail pairs. Resistor provides
an excess of unregulated the tail current. And CFP shunt regs
divert away all the low class electrons, leaving only the tastiest
regulated currents. Or some high scientifical nonsense like that...
Adds some gain in the process. Or more truthfully, pushing the
balance of existing gain unfairly toward the output side of the
pair. Thus shunt tail pair output current gain appears doubled.
I am kinda preferring the inverting version as shown. Holds
input transistors at constant voltage and current. No need for
cascode. And you get to push rails a little further apart for the
same VCE max. This is all because comparison to GND keeps
the input stage stationary between the rails.
Don't worry .models, its all in there. Just cropped the picture...
Old 9th March 2012, 01:46 PM   #2
Elvee is offline Elvee  Belgium
Elvee's Avatar
Interesting, but did you notice that CFPing also Q3 and Q7 improves the linearity, and more importantly makes it much more load-tolerant?
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 10th March 2012, 05:44 PM   #3
Nah: maybe this is load tolerance, 400WRMS into 2ohms?
Mind you, won't go lower than 5Hz without violating SOA.
Brands might differ where the 100mS line theoretically is.
I am not recommending 2ohm load for this transistor.
Lets look the schematic for a sec: I got rid the 8K2 on
the GND side. Why? Cause it might double offset instead
of cancelling, issue of inverting. I could be wrong here,
its not something I've thought long enough to be sure...
Getting rid the 8K2 makes a little unstable, not sure why.
But adding a 47u fixes that, and generally helps in every
way that I can determine. Even if you leave the 8K2, the
new 47u should probably stay.
If you bias an output for Class B, you can Muntz out a
great many emitter resistors all around. The feedback
loop assures nothing will run away, as long the output
doesn't short. If output short happens, game over...
Warn: This sim includes some noise on the power rails
Old 10th March 2012, 06:05 PM   #4
As for Elvee's mod, violates some of my pet concerns that may not matter.
I would just add a diode to the input side to keep collector voltages same.
Then again, I am also about to claim that imbalance was to our advantage.
Certainly more linear open loop in CFP vs CFP balance, but half the useful
gain of that stage is pushed back. Open loop gain improves only because
a transistor got added. I suspect we could add this same gain without re-
balancing the shunted pair and throwing half of it away. But we close the
big loop and this extra gain is going to be thrown away anyhow, so the
distinction of where gain gets sacrificed to linearity is a mere preference.
If closed linearity ends same, I'd just go whichever way used least parts.
Old 10th March 2012, 09:20 PM   #5
Elvee's Avatar
Probably acts as a base stopper: generally, such a resistor interact with B-C capacitance of the transistor and acts as a self compensation.
Except of course with "funny" circuits, like the Xquad, where it has the opposite effect (BTW, I stumbled upon the prime originator of this delightful circuit: it's a guy called Raimondo Caprio, and he invented it back in 1973).
That's strange: it probably prevents some kind of side mode mixing/conversion, but it shouldn't have a dominant effect on stability.
It could have an impact on linearity though, particularly on even order harmonics.
I think it could be a nice class A driver, but a 10K load limitation for good performances is too restrictive. 1K or 600 ohm is more realistic
Old 11th March 2012, 12:14 AM   #6
Bonsai is offline Bonsai  Europe
What's the performance at 20k say 12 or 13v pk into 600 Ohms?
Old 11th March 2012, 12:54 AM   #7
Circuit of Post #3 with clean power rails: 20K sine, 26VPP out, into 600R.
Old 11th March 2012, 06:42 PM   #8
Elvee's Avatar
The 1µs timestep doesn't do justice to the circuit's performance.
But on the other hand, when it is shortened under 500ns, it unveils instabilities.
It can be cured by reintroducing the 8K2 resistor.
Old 11th March 2012, 08:21 PM   #9
MiiB is offline MiiB  Denmark
nope it svings in a rather spiky way....made some feedback into the input transistors and reduced gain to 8 db with at supply of 18 V.. inserted current-sources for instead of rail-resistors...magnificent Pre-amp with distortion at -140dB...at 4 Volts out PP...but it inverts...
Old 11th March 2012, 10:19 PM   #10
Bigun is offline Bigun  Canada
Bigun's Avatar
Wow, that's really tiny - somebody gotta build it....
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Another of Ken's bizarre circuitsHide this!Advertise here!
Research on tubes and circuits simple circuits Cazcotty Tubes / Valves 6 16th June 2006 01:50 PM
85 powersupply circuits 58 charge circuits gev Power Supplies 0 31st July 2005 12:27 PM
Bizarre trouble... arold19 Chip Amps 26 16th March 2004 03:14 PM
Bizarre Phemomenon ? rwagter Everything Else 9 30th July 2003 02:02 PM
Copyright ©1999-2017 diyAudio
